what are the starting tricks for an 03yz450f
6 replies to this topic
  • rljjredhed
Posted January 31, 2005 - 02:20 PM
just read oldphat post about reckluse mod and has me thinking about keeping my bike, because i am close to dropping down to a 250 fourstroke so i can have more fun longer without getting so worn out, especially when i take my bike on the trails it is a bitch to start when i lay it down and it is hot and i am on a muddy incline any tips, it starts 1rst or 2cnd kick any other time but the little bit of tight trail riding i do man i don't have much fun trying to start my bike but man i love my bike but my wife won't let me have 2 one for trail and one for the track
thanks
  • slappie
Posted January 31, 2005 - 02:41 PM
My 450 was a pain to start until I began finding TDC before giving it the kick, instead of just kicking it over anywhere in the stroke.
Just nudge the kickstarter until you find the hard spot, release it to the top of the stroke and then give it a good kick.
It should start 1st kick 99% of the time with that method.
When I used to just kick it over and over, it would always start but sometimes would take much longer than others.
Basically, just like the 426 drill but no need to pull in the compression release (b/c it is automatic on the 450).
  • cgaluter
Posted January 31, 2005 - 03:03 PM
Everytime I lay down my 04 YZ450, starting it was very hard. Now it is easier because I learned to to crack open the throttle just a little bit. It starts in 2 kicks. Also find the TDC before kicking the lever.
  • StPeters21
Posted January 31, 2005 - 04:48 PM
I agree with slappie. Make sure you have patience and take your time. You should find TDC and use your hot start button. My '03 started much easier than my '04. Still wouldn't change to a smaller bike.Chad
  • John_Lorenz
Posted January 31, 2005 - 05:32 PM
not much you can do when the bike is laid over but try and keep it running
Bets Method if that occurs is to trun the gas off, and use the Hot start
Here is a link though on the starting drill
http://www.motocross...gtips.asp?id=87
Posted January 31, 2005 - 05:44 PM
There you go. :cry:
The bike generally gets at least partially flooded when it falls over and quits. In this condition, they need more air than fuel. As a result, opening and holding (NOT pumping) the throttle is usually the answer, since that reduces the vacuum applied to the idle circuit, and less fuel, or no fuel, will be delivered. How much to open it is what you need to learn by experimenting. Start at half and work your way down until you find out what your bike likes. This also works when you kill it with the brakes, etc., but that usually doesn't require so much throttle to clear it out.
  • yzf450jack
Posted January 31, 2005 - 07:59 PM
When I put a power now on my bike it made it starting much easier :cry:
  • Hot  50 replies
  • 10 replies
  • 5 replies
