XR650L: coming off idle the engine stumbles...
2 replies to this topic
  • bluerock5
Posted January 31, 2005 - 05:21 AM
XR650L: coming off idle the engine stumbles... after I pass the lower RPM, it runs fine - any suggestions how to fix it? Thanks
  • ghoti
Posted January 31, 2005 - 05:51 AM
What is the state of tune...or mods done?
  • Dual_Dog
Posted January 31, 2005 - 10:39 AM
Turn the pilot screw out in 1/2 turn increments, but don't go out more than 3 1/2 turns. To check the current pilot screw setting, turn it clockwise and count the number of (1/2) turns it takes to reach the closed position until it's lightly seated. This assumes that the tab either on the carb or screw has been removed. You'll be able to tell. The pilot scew is the located on the bottom of the carb closest to the cylinder going towards the engine.
Back it out again and add 1/2 turn. Ride & it see how it runs. If it's too far out already, or it gets that way after you've made the adjustments, chances are a larger pilot jet is needed. Check the archives for the "how to."
  • Hot  35 replies
Washington
  • Hot  32 replies
  • Hot  29 replies
  • Hot  60 replies
  • 9 replies
