Rekluse set-up
25 replies to this topic
  • GetSumBaby
Posted January 27, 2005 - 05:55 PM
Those of you running the Z-Start - What springs are you running, why, and type of riding you do?
I am putting mine on tomorrow and am curious what spring to start with? I ride trails, but not super technical (hungry Valley type). Very hilly and rough.
I also want to avoid severe engine braking when doing natural terrain jumping.
Thanks,
Ed
  • Dirty_Sanchez
Posted January 27, 2005 - 06:37 PM
I put mine in my 450 about a month ago. Follow the directions, pay attention to the installed gap, and enjoy the hell out of it once you get it dialed in.
I'm a woods guy with just a bit of track work and have what Rekluse calls the "Woods Spring". I think it's the lighter gauge spring in the package.
PM me and I can talk you through the clutch cable slack adjustment. This is pretty critical to get dialed in.
Dirty
  • 642MX
Posted January 27, 2005 - 06:39 PM
I ride MX mostly and use the soft spring.
  • Dano426
Posted January 27, 2005 - 09:10 PM
I ride mostly tight woods and use the heavy spring. It revs the engine a tad more on a hilly start. (is that a word "hilly"?)
  • vanisland
Posted January 27, 2005 - 09:25 PM
I ride hilly twisty trails & logging roads, light spring works well.
Read through the instructions carefully, shouldn't have any problems.
  • Desracer
Posted January 27, 2005 - 11:13 PM
The tighter the spring on the clutch arm the quicker it disengages the clutch for a rule of thumb. I tried the medium spring and had total freewheel when off the gas, the bike can roll really fast. I haven't had any problems jumping the bike with this clutch, ride like normal without a clutch lever thing.
  • John_Lorenz
Posted January 28, 2005 - 05:58 AM
been running it almost a year now
I am using the heavy spring with idle at about 1700
Ride woods 99% of the time and find this to be the best setup, Engine braking dont worry about it PERIOD, wont be an issue.
I find the setup I have if I need some a quick blip of the throttle and your slowing down. Remeber Stall Speed is important (Engine Idle) the higher you go, the more engine braking you will get as well as responce.
You can also get heavier ball bearings form Rekluse if you are not satisfied with setup, heavier bearings will engage quicker
  • mx426
Posted January 28, 2005 - 06:36 AM
I ride trails as well and use the lighter spring but I enjoy a little more engine breaking than most I guess. I have had no problems what so ever. Great mod!!You should love it.
  • GetSumBaby
Posted January 28, 2005 - 05:06 PM
OK - I got the light spring in, but its tightend all the way to the end. I wish the clutch would kick in a little later than it does. Does this mean I need to put the hard one in?
Ed
  • ncmountainman
Posted January 28, 2005 - 05:16 PM
yep. :cry:
  • GetSumBaby
Posted January 30, 2005 - 06:28 PM
ok - I took the bike out with the new Z-Start. All I can say is it is bad-ass!!! I didnt really notice a difference in engine braking. Actually it was kinda nice to be able to control it so easy! My only problem is that im using the stiff spring that is adjusted about half way and Im getting some surging at idle. I would like the bike to rev up a little bit more (more slip?) before the engine kicks in. I will have to call Rekluse and ask them about it. But all-in-all, second best mod I did to my bike, suspension being first.
Tomorrow I will re-check the installed gap and see if its still close to what they recommend.
Thanks all,
Ed
  • 426mankiller
Posted January 30, 2005 - 07:20 PM
My rekluse surged a little bit when I first installed it but the more it broke in the problem went away. I put about 80 trail miles on the clutch and I am in the process of doing the post break in install gap check and all I can say about the clutch so far is :cry: :cry: :cry: :cry:
One thing I did notice when I tore down the clutch is that the very bottom 1/2 width friction disc (that is mated with the boss spring that is removed during installation) toasted the drive plate next to it and I called rekluse and they said that the 1/2 friction disc should be replaced with a whole friction disc (just use the one that was removed originally for the rekluse) and that will take care of that problem if it happens.:cry:
  • ncmountainman
Posted January 30, 2005 - 07:33 PM
with that setup it should not be dragging. i've seen other people with 02 426's with the same complaint. maybe its bike specific? you could get the perch adjuster,i have mine set for a very low idle and quick engagement and at times when stopped i have to pull the lever to relieve the drag. thats with the adjustment all the way out and 5 TC balls though. you are about at the limit of your adjustment in the direction you need.:cry:
  • GetSumBaby
Posted January 30, 2005 - 07:59 PM
I have the perch adjuster. I put it on and didnt like the way it worked on my bike. So I pulled it off. I will put it on when I have more time to play with it.
And I putt all new friction discs and plates in the bike with the z-start. I took out the beveled piece, the inside ring, and the first friction plate. Im hoping the installed gap has changed and I can just fix it. Im already running two rekluse plates.
Ed
  • calhoon
Posted January 30, 2005 - 08:42 PM
Yep, the stronger the spring the higher the stall speed......AKA the more revs it takes to engage the clutch.
  • GetSumBaby
Posted January 31, 2005 - 05:54 PM
Did you move your bracket to look like this?
Thanks,
Ed
  • ockevin
Posted February 08, 2005 - 11:15 PM
are there any draw backs on the rekluse clutch ?
Anyone have pics of the install and finished product ?
Kevin
  • youngwerth
Posted February 15, 2005 - 07:51 PM
If you can't get any stall speed adjustment with the light spring, that means you have too much cable slack. Start your bike, put it in neutral, rev it to about 4K RPMs and pull on the clutch lever with one finger. You should feel light resitance for about a half inch of movement at the end of the lever, then it should get harder to pull. Your looking for a half inch of easy movement WITH the bike revved to 4K RPMs. Too much movement and the perch adjuster spring can't do it's thing. No freeplay and you burn up your clutch (just like on a regular clutch).
Any questions, give us a call at 1-866-REKLUSE.
  • Dano426
Posted February 16, 2005 - 07:36 AM
Kevin
Here is the rekluse web site that give the installation instructions for each bike. It shows diagrams and pictures of the install
http://www.rekluse.c...loads/index.cfm
  • xcracer123
Posted February 19, 2005 - 08:52 PM
Thanks for that link! I hadn't seen that before on the web site. They were much clearer and easy to read with the color pictures instead of the photocopied directions that I recieved. Certainly clarified a few misconceptions that I had.
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  113 replies
  • Hot  50 replies
  • Hot  47 replies
  • On January 15, 2017
