Anyone add shims to their forks?
3 replies to this topic
  • wayneoXCF
Posted August 03, 2001 - 04:00 AM
A good buddy who knows suspension tuning far better than me recommends using 1" PVC shims in the top of his tubes for better fork resistance. has anyone tried this? Im thinking about giving this a shot.....before I go out and buy new springs.
2001 WR426F - No stupid Grey wire, no lid, YZ Stop/Tank/seat, UNI,
  • npuzajr
Posted August 03, 2001 - 06:18 AM
They sell washers to put in on top of the springs. If I remember correctly your not suppose to exceed three. I dont know the thickness, but I would think its alot less than an inch.
  • MOmilkman
Posted August 03, 2001 - 07:24 AM
This past April I tried to put PVC on top of my springs for a little preload before going to the sand dunes. It turned out to be quite the joke. I cut the pvc about 1/2" and buy the time I got home and inspected the forks the pvc was smashed almost completely flat and was mangled badly. If your goning to take the time to try this method I definatly suggest the washers but the best method (And the method I went with) was heavier springs.
I went from .42 kg/mm to .48 kg/mm and it makes a heck of a difference. You should also re-spring the shock too if you do this.
I know its money, but trust me its worth it, the pvc isnt.
Darin in Missouri - 1999 WR400F
Enduro Heaven - Ozark Mountain TrailRiders
  • Scott_F
Posted August 03, 2001 - 09:49 PM
I should mention that preload washers MUST go under the springs, not on top.
