7 replies to this topic
  • bluerider450
Posted January 22, 2005 - 11:44 AM
i recently got a pcti muffler and tightened it up to much now i cant get the bolt out to rethreat or whatever it nees anyone have any ideas on how to get the bolt out of the subframe and be able to repair with out buying a whole new subframe?
  • Frostbite
Posted January 22, 2005 - 11:46 AM
Is it stripped and turning or seized solid?
  • bluerider450
Posted January 22, 2005 - 11:48 AM
the bolt can turn anyway you want it wont tighten anymore or come out though
  • Frostbite
Posted January 22, 2005 - 11:55 AM
I'm not sure which bolt you're talking about. Does it thread into the bike frame or into the muffler? Unless there's a welded nut that broke loose and is spinning you might be able get it out by putting pressure on the bolt as if you're trying to pull it straight out and turning it with a ratchet at the same time. If it bolts the muffler to the frame, prying between the muffler and the frame while turning the bolt may do the trick.
  • WheelsUp
Posted January 22, 2005 - 12:04 PM
Ditto above.
Once it's out, re-tap the subframe to the next size, or if the muffler hardware won't allow for a larger fastener, then clearance drill through the sub, use a longer bolt, and put a pair of locknuts on the inside.
  • DoctorRzed
Posted January 22, 2005 - 12:17 PM
Simply drill it out :cry:
  • etownyzf
Posted January 22, 2005 - 01:52 PM
drill it out-then put in a longer bolt & a nut on the other end
  • bluerider450
Posted January 23, 2005 - 11:16 AM
its the bolt that holds the muffler to the subframe thanks ill try it doesnt sound to hard i dont think
  • Hot  33 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • 0 replies
Need help by Goforaride
  • Hot  68 replies
  • Hot  79 replies
