Opinins on 2003 Yz450f
10 replies to this topic
  • timvan
Posted January 20, 2005 - 09:36 AM
Just curious on the good, the bad and the ugly....
local dealer has one here...think he has a sticker of $4400.00 on it...I wouldnt pay that but so be it..
What do I need to know on this bike before looking...any info greatly appriciated!!
TIA
Tim
  • MichiganMXer
Posted January 20, 2005 - 09:49 AM
Its a beast. Hold on.
  • timvan
Posted January 20, 2005 - 10:17 AM
Well nevermind...they sold it...
Posted January 20, 2005 - 10:20 AM
Great bike. No real mechanical faults except for the unfortunate tendency to eject the cheesy little plug the blocks off the bore where the decomp shaft used to go, but that's true of every YZF from '03 up, and it's easy to correct.
Almost everyone thinks the bike is a little too aggressive as delivered. The most common thing done about it is the addition of a heavier flywheel. In fact the flywheel delivered on all '04 models is 5oz heavier than the '03 came with. If you use a weld-on design, like the GYT-R or Dr.D flywheels 4-6oz will usually do it.
The only other thing is that the '03 clutch tended to pull heavy and chatter a bit. That too, can be fixed fairly easily and cheaply.
The '04 got larger fork tubes, but the forks on the '03 can be set up to work well. The '04 also had Ti footpegs.
  • DPW
Posted January 20, 2005 - 02:23 PM
disagree....over 30 Novice\Beginner no problems here holding on.
  • BigDesto
Posted January 20, 2005 - 02:53 PM
????????????? the 03 has the hardest hitting power out of any YZ450 made!
  • OHVrider
Posted January 20, 2005 - 03:06 PM
I like mine, but it does have a couple problems:
1. Too light of flywheel (easy fix, buy a heavier one)
2. The TPS squirts too much fuel and the BK mod is harder on the 03's (I'm still playing with this)
3. 4-speed gear box is not as versital, but not as bad as the other guys make it out to be.
The good points are:
1. Carries more oil than Honda, or KTM
2. More stable than Suzuki, KTM, not sure on Honda close i think
3. My cousin' s husband put 200,000 miles on a 1998/9 WR400 that he bought in NV cause CA didn't have them yet. he dual sported it and rode it from Truckee where he lives to everywhere for 4-5 years. (Just regular maintaince and parts, nothing major)
4 YZ's come with a warrenty although short. Good luch with anyone else.
That said I think all the 2000 and newer bikes are pretty good, Each has flaws, find em and fix em and you'll be happy. I look more at ergo's now than anything else. Which bike fits me best.
Cheers,
  • viperman
Posted January 20, 2005 - 03:36 PM
Awesome bike..............Mine is insane.............
  • PimpdYZ
Posted January 21, 2005 - 06:34 AM
Great bike... very fast!
Posted January 21, 2005 - 09:47 AM
True
The TPS has nothing to do with squirting fuel, the accelerator pump does that. Maybe that's what you meant. The TPS is said to cause a "hit" at around 8000 rpm, but this turns out to be a soft spot in the power curve that feels like a hit when the engine recovers, and can be solved better with the right exhaust system.
The 4 speed covers nearly the same gearing range as the '02 YZ426 5 speed, and IMO, the gear spacing is still closer than it needs to be. I have mine geared so that 1st is identical to the 426, and that puts my 4th about 65% of the way up the gap between the 426's 4th and 5th. It WILL go 89 mph on pavement like that. I don't see how having to do less shifting is less versatile, unless you're going to compare it to a WR...
Yes to both, and add to that that the YZF is a dry sump, which is technically superior from several standpoints, and I AM sure it's more stable than a CRF.
They are indeed tough. Especially the older ones with SS valves.
:cry:
  • x2stroker
Posted January 21, 2005 - 01:28 PM
I love my 03 450 :cry: . It has more power than I'll ever need on any MX track...
  • Hot  50 replies
  • On January 15, 2017
  • Hot  47 replies
