Battery on a XR600
8 replies to this topic
  • Fredda
Posted January 19, 2005 - 11:34 AM
I'm planning to put a battery on my XR600, but how will I do to manage the charging of it? As I know, The XR650L have a battery for the start engine, anyone knows if the same batterysollution will be able to fit onto a XR600?
(don't ask why, pics will be put up here when I'm finished with the modifications)
Tnx
  • StevePSD
Posted January 19, 2005 - 04:20 PM
You will need a rectifier/voltage regulator to charge the battery. The current stator output is AC, which will work ok on AC current, but a battery will not.
You can buy them from Baja Designs or Ricky Stator for around $40.
Are you planning to convert the bikes electrical system to DC? On my XR600 I am running a 200Watt Ricky Stator. This has two seperate AC coils of 100watts each. I run the headlight off one AC coil. The other AC coil is run thru the rectifier/voltage regulator/battery so the rest of the bike is DC. I'll switch this to all DC when I get a headlight on/off switch (I have to be able to have the taillight lit for a minimum of 15 minutes with the engine off and my battery would not support the headlight being on as well). I'll then connect both stator lighting coils together and have a single 200watt DC system.
Hope this helps.
  • millydog
Posted January 20, 2005 - 11:57 AM
:cry: steve were did you position the battery on your xr 600 as i want to fit one to mine.cheers Gareth
  • billmunson
Posted January 20, 2005 - 03:23 PM
My battery is about the size of 2 packs of smokes. It sits on top of the air box/snorkel removed/ under the seat .
  • millydog
Posted January 20, 2005 - 04:25 PM
cheers bill there is not a lot of room under there but i will give it a go.thanks Gareth
  • StevePSD
Posted January 20, 2005 - 06:59 PM
I put my battery (a sealed lead-acid unit) in the rear fender bag, as a temporary measure to pass the lighting test. It's final resting place with either be under the air box, or possibly in the seat- cut a slot in he plastic base in the rear of the seat and place it there, horizontally. That area is not used - I don't sit that far back, nor do I have passengers.
I am looking at using either a Panasonic 12v 1.3Ah battery (3.82"l x 1.87"w x 1.97"h), model #LC-R121R3P or a Panasonic 12v 2.2Ah battery (6.97"l x 1.34"w x 2.36"h), model #LC-R122R2P.
These are available from digi-key http://dkc3.digikey....F/T051/1360.pdf
I have also seen similiar sized sealed lead-acid batterys used in radio-controlled cars.
Hope this helps.
  • Fredda
Posted January 21, 2005 - 02:16 PM
Will the same method work for stock stator aswell?
Don't fell for paying much money for a 200w stator just to have a battery on the bike...
So lets see if I understood it right; first DC the currant for the battery and then just put the battery in? Don't it need a chargeingrelay(?)? The whole bike dont need to be DC, but I gues it would be simpler to have all the bike the same. The thing is that I'm going to put cold cathode/neon lights on it (I know, a bit corny but &%$#@!....)
  • StevePSD
Posted January 21, 2005 - 06:33 PM
With the stock stator you could leave the headlight/taillight AC, just like they are now. You would then need to splice into the stator output lead and put the rectifier/voltage regulator in line, the DC output from the rectifier/voltage regulator would go to the battery and to power whatever DC devices you have. You will have to be careful not to exceede the capacity of the stock stator - which I believe is somewhere around 60-80 watts, depending on the year of the bike. Depending on the headlight you have, it uses anywhere from 35-55 watts.
Hope this helps.
  • Fredda
Posted January 22, 2005 - 12:13 AM
So i don't need to use some more stuff like relays etc?? Just put the DC currant on the battery? Sounds great!!
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  60 replies
Washington
  • Hot  32 replies
