Wr450 Mods
6 replies to this topic
  • gregwr450f
Posted January 19, 2005 - 12:24 AM
:cry: CAN SOMEONE PLEASE PUT UP A LIST OF ALL THE FREE MODS THAT CAN BE DONE TO A 04 WR450F :cry:
  • cruise
Posted January 19, 2005 - 03:01 AM
cut the grey wire
cut open the air box
put in the smaller throttel stop
mine came wiyh a 15 tooth front sprocket on it and a 14 in the spare's
put it on.
under the the number plate theres a crappy plastic reflector which hangs down cut it off just under the number plate.
the best thing i did was the JD jetting kit and zip ty fuel screw and a YZ pipe.
  • elton
Posted January 19, 2005 - 05:03 AM
This site details the mods, free and other, for the WR250; the mods are similar for the WR450.
http://thumperfaq.com
I did these: Remove the exhaust insert, Remove the airbox snorkel, shorten the throttle-stop and disconnect the grey wire under the gas tank.
Next I'm going to remove the AIS using the Lowedog kit, try a pro moto billet exhaust insert when it ships for the 2005 and may consider the JD kit (unsure if I need it since the WR appears to run perfectly as is).
Elton
  • dirtguy
Posted January 19, 2005 - 11:14 AM
what is the purpose of the grey wire under the tank
  • elton
Posted January 19, 2005 - 11:51 AM
Go to the site outlined; It'll explain it. To get directly to this section of the site:
http://www.thumperfa...m/gray_wire.htm
Elton
  • gregwr450f
Posted January 19, 2005 - 01:33 PM
Thanks For Your Help, Iam New To This Site And It's Awesome.
  • dirtpumpernick
Posted January 23, 2005 - 06:34 PM
if you want to get serious add a yz cam kit and needle with a yz slip on and cut gray wire under tank. these things will really add to power. the stock wr is a lazy bike. i hated mine until i added these mods. its awesommmmmmmmmme now
