good motor mods for '00 yz426
10 replies to this topic
  • SSpeeDEMONSS
Posted January 17, 2005 - 10:34 PM
im in the process of putting my motor back together(seized the bottom end thanksgiving weekend at glamis) and i was wondering what you all think would be the best mods for me to do while its apart. im replacing all the bearings, auto decomp camp, and hi-comp piston. if i do the exhaust should i also do the intake cam? and will be doing the '01 clutch mod too.
  • Fastest1
Posted January 17, 2005 - 10:45 PM
No need for the intake cam.
  • Matt96xr6
Posted January 18, 2005 - 07:57 AM
Get the JD jet kit and do the BK mod to the carb. You should have more than enough power
  • yz426onNOS
Posted January 18, 2005 - 08:19 AM
13.5.1 compresson, larger bore, hot cams both exhaust and intake they include the auto decompressor, kibble white SS one piece valves are a must! Maybe even porting and polisihing.
  • Chills
Posted January 18, 2005 - 12:19 PM
Hey YZ426onNOS,
Can you shed some more light on the kibble white SS One Piece Valves for me...Thx Bro
  • SSpeeDEMONSS
Posted January 18, 2005 - 08:23 PM
ive already done the BK carb mod and was planning on getting the JD jetting kit, just forgot to mention that.
yz426onNOS, if only i had the money... but, if i did have the money, it would be a stroker crank plus big bore equals 488cc. 13.5 piston, web cams, port and polish, and kibblewhite SS valves. that sounds about right. too bad its all out of my league $$ wise.
oh yeah, i ordered the hot cams auto-decomp exhaust cam today as well as the hi-comp piston.
  • blue_beast_wins
Posted January 18, 2005 - 08:40 PM
Drill and tap the breather hole in the case beheind the barrel, best to do it while the cases are split. :cry:
  • drc02
Posted January 18, 2005 - 08:56 PM
replace the crank bearings with ceramic
  • Bryan47
Posted January 19, 2005 - 04:25 AM
Ceramic?? Where do you get 'em?
  • myoung
Posted January 19, 2005 - 09:51 AM
Check the transmission gears for excessive wear.
  • Vibeguy
Posted January 19, 2005 - 02:50 PM
Forget the ceramic bearings, way over priced and the only advantage is more resistant to chemical attack, unless of course you have a chronic chemical attack on your big end!
My personal favorite, the TT decomp plug!
  • 5 replies
  • Hot  30 replies
  • Hot  50 replies
