fuel mixture screw out or in for colder temps?
2 replies to this topic
  • rljjredhed
Posted January 15, 2005 - 04:19 PM
sorry but i am rookie when it comes to wrenching, it has turned cold in nc and my bike seems to be idling higher due to the temps and not starting on the first kick as it normally does, out or in for the cooler temps on the fuel mixture screw 03 yz450
thanks for the help
  • sirthumpalot
Posted January 15, 2005 - 04:26 PM
On these carbs it's a "fuel" screw, so out for a richer mix (out for colder temps). If youi can't get enough adjustment with the fuel screw then you may need to go up a size or two on the pilot jet.
Posted January 15, 2005 - 04:30 PM
Out. You need to enrich the mixture a bit. Since the screw meters fuel, bacling the screw out makes it richer. Check this procedure out as a guideline:
http://www.thumperfa.../jetting.htm#PJ
  • 0 replies
  • Hot  30 replies
  • 10 replies
