Rekluse clutch cable
6 replies to this topic
  • Ronnie Mac
Posted January 15, 2005 - 02:32 PM
I'm in the process of installing my z-start and was wondering if the longer cable (that wasn't mentioned when I ordered) for the perch adjuster is needed? In the manual it says some wr450 will need a longer cable but doesn't say what year of bike, mines a 2003. Also how do you know if your bike has a clutch boss spring? Again it says not all wr have one. I looked in my manual and could not see one in the exploded view. I sure could use some help. :cry:
  • Ronnie Mac
Posted January 15, 2005 - 11:16 PM
Never mind boys/or girls. I seemed to get it to reach. I started it up and put in gear and gave some gas and it did move forward.( in a small shed, at 11 o'clock at night, in town).Tomorrow I will give it a spin.
  • BigDavey
Posted January 17, 2005 - 06:12 PM
Did you get a chance to ride? I installed mine in Dec but have not had a chance to get out ride except in front of my friends shop where we installed it. I have a 2004 WR450 and I had enough cable. Let me know what you think. It suppose to warm up, its been well below zero here but today it was almost 40.
  • duckboy
Posted January 17, 2005 - 06:28 PM
BigDavey make sure the clutch disengages fully when you rev the engine in gear. I had to go up a size on the throw out spacer( ball bearing) due to the difference in the clutch plates on my 04' that rekluse overlooked from the 03'.
  • matt_rohr
Posted January 17, 2005 - 08:39 PM
Do these things have or can they be set up to exibit compression breaking? thanks, Matt
  • Desracer
Posted January 17, 2005 - 10:28 PM
The nice thing about this clutch is you can set it up how you like it. Mine seems like normal as for the engine breaking. I started coasting down hills years ago for a challenge so now with this clutch I let it idle and I fly. To get engine braking I just crack the throttle and the clutch engauges and back to normal. With a spring adjustment system you can set your clutch up how you like it. I rode in the snow with it and had a blast! The bike was easier to control with this clutch and chopping the throttle to disengauge the clutch let the rear end turn instead of skidding so I had better control. Works the same in the mud too!
  • BigDavey
Posted January 18, 2005 - 06:05 PM
Duckboy thanks for the advice but I learned the hard way and to disassemble and switch the spacer.
