Rear sprockets are they worth it?
11 replies to this topic
  • Geib2269
Posted 13 January 2005 - 06:44 AM
I was looking on this forum and saw that a 49 to a 47 sprocket on the rear really makes a difference. But when i was looking it up i saw that one cost about 60$ and i was just wondering if they are really worth it and what set up of sprockets should i get to give me bettter low end but keep some of the mid and high end. I have an RMZ-250 so if anyone has any suggustions please.:worthy: :D :confused: :confused:
  • kxthumperdude777
Posted 13 January 2005 - 07:34 AM
i donno about the sprockets but if you do get a sproket buy a chain to at the same time. if you have an old chain with a new sprocket, the chain will break very quickly.
  • zuki88
Posted 13 January 2005 - 11:50 AM
It won't break the chain, using a new sprocket and an old chain will however result in the sprocket getting worn very quickly. You're better off going up 1 tooth on the front sprocket, the change will be approximately the same (1tooth on the front= 3 teeth on the rear) and the front sprockets are only about 20 bucks. Good luck.
  • freestyle694
Posted 13 January 2005 - 03:25 PM
I dont know what stock gearing is on an 04, but the 05 is 12-48. 13-50 is suppose to work real well. Good luck!
  • Geib2269
Posted 13 January 2005 - 05:37 PM
Thanks for the replys guys so i should go wit a one tooth down on the front and leave the back alone. I also bought a new chain already because mines worn.
  • zuki88
Posted 14 January 2005 - 12:19 PM
The stock gearing on both bikes is definetely 13/48. If you go down to a 12 tooth you will have more low end. BTW, if you're replacing the chain because it's worn then you should also replace both sprockets; if you don't the new chain and new sprocket will wear very quickly.
  • merlinn
Posted 14 January 2005 - 04:01 PM
I run a 13/49 with a power now and have tons of low end.
Merlinn
  • SpLiZaaT
Posted 14 January 2005 - 09:25 PM
by going 13/49, you noticed quite a bit of top end loss though correct? WHat kind of riding do you do?
I ride woods mainly, now discovering track, and have heard it's a good idea to go +2 in the rear...anyone running only +2?
  • merlinn
Posted 15 January 2005 - 05:41 PM
If you run out of gear in fifth after the change, then your losing top end. But, for track and woods use the + 1 or 2 teeth is OK. I really like the +1 and powernow combo. The P/N adds to the low end and +1 does not chop to much off the top.
Merlinn
  • freestyle694
Posted 16 January 2005 - 07:21 AM
My bad stock is 13-48 I meant 14-50 sorry!
  • DJ_VT
Posted 29 January 2005 - 04:35 AM
Will a 13-50 make the stock gearing on a 05 slightly higher geared?
  • merlinn
Posted 29 January 2005 - 07:21 AM
No, it will make it lower geared. Or put another way, it will lower top speed but quicken accleration.
Merlinn
