please help...DrD hot start user on a 426
5 replies to this topic
  • Math
Posted January 13, 2005 - 06:16 AM
Hello!
How much space is required to install the DrD hot start?
I'm asking that because I have the Ty Davis tank. It is going down very low and I don't know if the tank is going to clear the hot start tubing.
How wide is it from the carb? Is it wider than the stock hot start in shut position? Please specify details about how you take the measurements.
I would appreciate your help a lot.:cry:
Many thanks in advance:thumbsup:
  • Flamed1
Posted January 13, 2005 - 10:39 PM
I am unfamiliar with the Ty Davis tank as I believe it is an IMS, but I have a 2001 426 with an Acerbis tank and while they are very close to eachother,it works. If you attempted to plumb the tank w/2 petcocks, you already know there is very little real estate to thread anything through there with a larger tank:D . I do keep an eye on it as I am concerned as you are, but I have had no problems with it for the last 3 years. Sorry, I am not in town right now so I cant measure mine for you. Good luck!
Brian
  • Math
Posted January 14, 2005 - 04:15 PM
Brian
Many thanks Brian!!!!!!!!!!!:cry: :cry: This information helps me more than you would have thought at first.
One of my friend here has the Acerbis tank and we have the same clearance from the carb so if it works with your acerbis tank then it is probably going to work with my Ty Davis one.:cry: :cry:
I'll give it a try.
IMS builts ZipTy tank. For 98-02, IMS and ZipTY are not the same but I think that since the 450 came to the market, IMS produces only one model: the ZipTy one. I might be wrong on the later statement though.
Thanks for your help again!
  • RSA210
Posted January 14, 2005 - 09:31 PM
Math,You should have no problems.Running a Ty Davis tank w/ a Dr. D hotstart.
'02 WR 426, Had the tank & the hotstart on since the bike was new.:cry:
  • PowerFiend
Posted January 14, 2005 - 09:44 PM
I have a Dr. D hot start with a ZipTy tank on an 02 WRF, it fits fine.
  • Math
Posted January 17, 2005 - 12:38 PM
Man, I love this forum! :cry:
Thank you much for all the input! :cry:
Just bought mine. :cry:
