05 kxf black smoke....Advice
Started by crfrookie, Jan 12 2005 06:33 PM
11 replies to this topic
Posted 12 January 2005 - 06:33 PM
Posted 12 January 2005 - 07:13 PM
well i havent done any thing to my jets yet but just from what i know isthat you need to do some fuel screw adjustmants. Ethan
Posted 12 January 2005 - 07:41 PM
I ride my bike while it is smoking blue and I havent been able to find any problems,although that does not mean there are none
Posted 12 January 2005 - 08:13 PM
Mine does the same. The piston is running one ring set (1 comp + 1 oil scraper) and when it is first started the ring does not seal fully until the engine reaches operating temperature. Also the bike is running rich from the choke. I bet the problem goes away after a short time. It not a fault but a consequence of running one ring.
It should not be blowing a smoke screen just a small amount of black/blue smoke coming out the of the exhaust especially when the revs are increased
Posted 12 January 2005 - 08:26 PM
My '05 KXF does the same.......blows some black smoke after starting when cold.
With 30 trouble free hours so far, the smoke at start up hasn't worried me
Posted 13 January 2005 - 12:02 PM
Black Smoke at startup is due to there being too much fuel. This is perfectly normal and nothing to worry about. If your bike is making blue smoke this is due to a little oil being burned and isn't a problem as long as it goes away once the bike warms up. If you have any kind of smoke after the bike is warmed up, I wouldn't ride it as there is something wrong with it.
Posted 13 January 2005 - 01:20 PM
Check you spark plug. This will tell you more then anything will. A lot depends on your elevation and weather conditions. These bikes are jetted for sea level from the factory. If you are higher then 3000 feet above sea level, you should have gone down one size not up. This also depends alot on the temperature and humidity. If your plug is black and sooty looking you are defenately rich. To much fuel. If it is black and wet (oily) looking it is oil. Your plug should be kind of tan for good jetting. I would bet you are to rich on your jetting. Just a thought. Hope this helps and happy trails!!
Posted 13 January 2005 - 01:23 PM
One more thought. There are a lot of threads on this forum about jetting. Do a search on jetting and a little reading. If the bike is new it should not be a problem with the rings. My bike does not blow black smoke at all and the plug is a nice tan color........ good luck
Posted 13 January 2005 - 05:49 PM
everyone here has good information listen to them cause they are right
Posted 13 January 2005 - 06:38 PM
Thanks for the information everyone, unfortunatly I will not be able to get out on the ice again until the weekend. I will then watch carefully to see if the black smoke goes away after it is warmed up, as well as check the plug. Hopefully it is just normal, cause the bike doesnot even have 3 hrs. on it yet. I am pretty new to the dirt bike scene and don't know alot about jetting and stuff, but I live in wisconsin and it gets cold here in the winter so we run on the ice. Question. Is it necessary to change jetting on a thumper when the temperature falls into the single digits? I changed the main jet to a larger size and maybe I am to rich, Could this be the cause of the black smoke? If it is too rich, is it going to cause any damage to the bike? Or should have I just left the stock jetting in? I will do a lil reading on some of the other forums concerning jetting and how it works. Thanks in advance.
Posted 14 January 2005 - 07:17 AM
Running your bike rich will not hurt the engine itself. You may foul your spark plug though. I would put the stock jet in first. What is your elevation?? The cold temperature means that the air is more dense and would call for a bigger depending on your elevation. If you are above 3000 ft I would just put the stock jet back in and try it. When the bike is rich it will run a little better on the bottom and in the middle but will kill the topend. Good luck
