chain oil?
12 replies to this topic
  • GixxerBitch
Posted January 12, 2005 - 11:05 AM
I used some Silkolene, but to be honest I found it gives to much 'fling off' What do you guys think of chain waxes such as those made by Castrol? What would you recommend?
  • Mattheww
Posted January 12, 2005 - 04:31 PM
I like Bel-Ray SuperClean chain lube myself....
  • Indy_WR450
Posted January 12, 2005 - 06:59 PM
Ditto I use Super Clean it turns white and paste like. It will never fling.:cry:
  • black_n_blue_thumper
Posted January 12, 2005 - 08:35 PM
ditto the Bel-Ray:applause: :cry: :cry: :cry: :cry:
  • wantmorepower
Posted January 12, 2005 - 08:40 PM
bel-ray works wonders.....
  • marcusmoberg
Posted January 12, 2005 - 08:56 PM
Bel-Ray is the best! Don't buy anything else!:cry:
  • TrialsRider
Posted January 12, 2005 - 09:05 PM
Ill 6th that...use it on all our bikes.
  • Stonie426
Posted January 13, 2005 - 06:39 AM
I used to use Castrol chain wax which was fairly OK. But have recently gone onto use Putoline's new Tech Chain which is a ceramic based wax formula with added PTFE - you should give this a go, I don't think you will be dissapointed with it. Only problem, it tends to go everywhere when you spray it on your chain - just be carefull.
  • GixxerBitch
Posted January 13, 2005 - 02:55 PM
Cheers mate!
  • NewBee
Posted January 13, 2005 - 04:51 PM
Frome what I have been reading is that the spray lith grease is the best for trail and enduro because it doesn't flick off and it seals the chain from water.
  • Borgas
Posted January 13, 2005 - 05:01 PM
Hello all
A friend of my who is specialist in lubrificants [Works in GALP industries] tells me only one thing "never mix ceramic with silicone lubricants" because you risk to send transmission to garbage. Their proprietis are not compatible.
  • briter
Posted January 13, 2005 - 10:13 PM
I used to use PJ1 chain lube, but it also flung black crap all over. I now use Maxima chain wax and have had success with it for several years on both my old zuk and my WR450.
  • StockJockey
Posted January 14, 2005 - 04:47 AM
It's already been said but I'll say it anyway ... go the Bel-Ray. Use it on a nice hot chain for best results.
