motor rebuilding specs
1 reply to this topic
  • nicogc
Posted January 11, 2005 - 06:14 AM
hello everryone!! do any of you know if there is somewhere on the web where i can download a shop manual for a XR600R '98-'99, or where ca i find information for specs on compression tests, cilinder diameter, ring clearances, etc. i want to know if i have to rebuild the top end on the bike. thank you very much for any info you can send me.
  • bootlegger2
Posted January 14, 2005 - 03:42 AM
well if it smokes while you are ridin it needs rebuilt i dont know about compression i would say anything above 150 is good ring clerances if you got it down .003 per inch of bore a 4 inch bore needs a .012 ring gap
i havent realy looked for any web sites with the info you want though maybe the honda web site can give you a spec sheet about it when it was new bore stroke stuff like that
  • Hot  60 replies
Honda XR650L 2017
  • 0 reviews
  • 9 replies
  • 17 replies
