wr400 cylinder
2 replies to this topic
  • my98mugen
Posted January 10, 2005 - 08:07 PM
im putting new rings in my wr400 thats never been opened before. the cylinder walls are clean with no scores. i can still see the old cross hatches.
my question is, do i need to hone the cylinder before i put in the new rings or are those walls to hard to even make a difference?
_________________
Desert F240
GP F118
  • Indy_WR450
Posted January 10, 2005 - 08:18 PM
Dont you want to send the jug out to be honed and recoated?:cry:
While you are at it on a 400 I would check your cam chain crank sprocket.:cry:
You might have hooks only instead of sprocket teeth!
countershaft bearings tend to go before the main crank.
How are the valves seating? New valve seats, springs, valves and guides are probably a good idea if you are doing the cylinder.:cry:
  • burtonbutt1
Posted January 11, 2005 - 06:19 PM
In order for new rings to seat, cylinder MUST have fresh hone.
good luck
Marc
