Fork seals?
6 replies to this topic
  • GixxerBitch
Posted January 10, 2005 - 03:06 PM
Should I use genuine Yam seals or is there something else better on the market?
I'm learning about this bike pretty fast now. Just checked my swing arm and rub block, they're looking pretty bad, gonna try some of these mods I've been reading about and pretty quickly too!
Cheers.
  • Gadsen
Posted January 10, 2005 - 03:41 PM
Been there, done it plenty of times on my old WR426. Had horrible luck with aftermarket seals. Best luck with OE seals. IMHO, OE is good stuff and the price is reasonable too!
  • lewichris
Posted January 10, 2005 - 04:36 PM
I agree, OEM seals have been the best for me so far.
Chris
  • ckulzer
Posted January 11, 2005 - 07:09 AM
Always remember to greese the seal wiper per the manual. I have gone 900 miles of mud and sand without a seal failure but I apply grease often.
Also bleed the air out of the forks with the front wheel off the ground before every ride.
Ride fast -take chances.
Chad
  • KaBooM
Posted January 11, 2005 - 07:36 AM
I agree. Aftermarket OEM seals are just licensed molds from other manufatures (NOK, Athena).
Here is a couple reasons OEM and aftermarket OEM (copies)seals have.
1. They have a two lip design= Bridging, meaning, dirt gets trapped in between the seal lips allowing water, dirt, air and oil to pass back and forth causing rapid internal ware and tear.
2. Pivoting= During the fork tube deflection, the OEM seal and DU bushing are the pivot point which take the brut force of impacts. Causing damage and rapid wear and tear to both items which leads to the problems in reason #1.
I have dedicated the last 2.5 years studying the above stated reasons plus more. I also decided to do something about it.
Everyones opinions count for this is what keeps the world turning, but it is highly recommended to research options.
Good Luck, Rob
  • drewpeacock
Posted January 11, 2005 - 04:12 PM
Please help me understand what he just said. Does he have a design that is better?
  • Desracer
Posted January 11, 2005 - 05:28 PM
I have seen the stock OEM seals in aftermarket bags with some amazing claims! Same seals but they were higher priced, beware!
