Hard clutch pull on 03 YZ450F
7 replies to this topic
  • tony4
Posted January 10, 2005 - 09:49 AM
I have an 03 YZ450F and was wondering what is the most effective way to make the clutch pull a little easier. The pull on the 04 YZ450 is so much better but I'm guessing you would basically have to buy the complete clutch system like basket,springs plates,cable and brackets to achieve the same same pull. Any CHEAPER suggestions would be greatly appreciated. thanks
Posted January 10, 2005 - 09:55 AM
I don't know for certain, but I'd bet it was mostly a matter of the springs and pressure plate. I'd suggest the Hinson, or GYT-R components (the GYT-R stuff IS Hinson, last I saw)
My Hinson clutch has been an easy 2 finger deal ever since I got the bike. It's the most totally perfect clutch I've ever owned on any motorcycle. :cry:
  • BigDesto
Posted January 10, 2005 - 10:03 AM
I put the 04 set-up on my 03 yz450 works alittle better! It's routed different from the 03!Also the clutch lever mod will make the pull easier! Just drill another cable hole in front of the existing hole and rerehm where the cable route is! Works great!
  • Satch0922
Posted January 10, 2005 - 10:58 AM
this is the first thing to do......it works....Best of all it's free.
  • BigDesto
Posted January 10, 2005 - 11:11 AM
:cry: :cry:
  • tony4
Posted January 10, 2005 - 09:09 PM
All I can say is unbelievable. I did the lever mod like you guys suggested, the difference is night and day. With a freshly lubed cable it feels close to a 125 clutch. Thanks for help guys.
  • BigDesto
Posted January 11, 2005 - 09:06 AM
Only costs a couple of bucks if you screw up the 1st one!:cry:
  • yzf450jack
Posted October 19, 2007 - 07:54 PM
Magura Jack hydraulic clutch with a Enduro Engineering lever and change the 10mm master for a 9mm and you can pull in the clutch with your little finger Yup that's right the little finger
