oil
7 replies to this topic
  • Brian M
Posted January 09, 2005 - 12:44 PM
I have an 05' WR 450. What oil do you guys recomend? I was going to use Valvoline's Dura Blend. Also what do you recomend to clean the drive chain? In the past I have always used kerosene, but I have recently read that it is not recomended for O-Ring chains. Thanks.
Brian
  • Indy_WR450
Posted January 09, 2005 - 01:18 PM
Kerosene has always been OK on O-ring chains.:cry:
  • cadvette
Posted January 09, 2005 - 01:34 PM
The oil you suggested using is a automotive oil. Automotive type oils are not recomended oils to be used in your bike. These oils have additives in them that reduce friction that will cause your clutch to slip. You should only use a motorcycle specific oil only in you bike. Read the manual it will tell you about this. You can get motorcycle oils in synthetic or synthetic blends or just regular oil. Go to your local bike shop and they will help you decide which oil is for your liking.
  • Bamster
Posted January 09, 2005 - 02:19 PM
I"ve always used kerosene to clean my O-ring chains.:cry:
Some say to use Mobil 1 red cap, some say not.
It's always worked for me.:cry:
  • yz426onNOS
Posted January 09, 2005 - 05:34 PM
Please use the search feature. I use red cap.
  • xcracer123
Posted January 09, 2005 - 05:46 PM
Use motorcycle specific oil in your bike. For the amount the bike takes, it's worth the extra price. As far as the chain goes, I use a chain specific brush to clean mine after washing. It's called a Grunge Brush and can be ordered from White Brothers. It's only $15 and last forever. It has brushes on 3 sides to clean the whole chain at once. Then you just let the chain dry after rinsing with clean water! Afterward, I warm up the chain and apply an o-ring safe lube. Has always worked for me and I seem to have better chain life than all my riding buddy's. Just my 2 cents!
  • lewichris
Posted January 10, 2005 - 05:00 PM
full synthetic, 15W-50 i believe.
  • dangermouse007
Posted January 10, 2005 - 11:27 PM
Morris Semi Motocross Oil, and I always clean with Parafin and WD40.......and re Oil with Gear Oil....
