Sore left wrist!!!!
4 replies to this topic
  • cabage
Posted January 09, 2005 - 11:45 AM
Anyone run a Magura clutch for a YZ426 02, I need some help. I have the whole thing connected with loads of pressure but the needle will not go in any further when the lever is pressed. From what I can see the needle needs to sqeeze in when the lever is pressed in order to release the clutch plates. Any help please, what am I doing wrong:excuseme:
  • yzf450jack
Posted January 09, 2005 - 03:29 PM
Is the return on the arm still hooked up if so un hook it so it can pump up and some kit's need a spacer to take some play out for a full pull and then there is the little red knob you can fine tune
  • cabage
Posted January 09, 2005 - 05:10 PM
I have unhooked the spring on the clutch arm but still no joy, the adjuster knob doesent seem to do anything either.Any more sugestions always appreciated, Cheers, Cab
  • yzf450jack
Posted January 09, 2005 - 07:45 PM
In the instructions it talks about a spacer at the slave but there is none There should be 2 to 4 mm freeplay Oh and you have to grind the arm or it will bend the slave's shaft :cry: don't use dot brake fluid :cry: mineral oil only and all else fails www.magurausa.com Oh and your clutch WAS working with a cable right !
  • cabage
Posted January 09, 2005 - 08:59 PM
Yep to all the above, cheers for the web address and your help, Cab
