Where to get Hot Start lever kit (01)426
5 replies to this topic
  • Thumper728
Posted January 08, 2005 - 01:35 PM
Where can I get the hot start lever and cable for my 426
  • Flamed1
Posted January 08, 2005 - 01:40 PM
I picked one up for my 2001 a few yers back at Dr D. Been really happy with it so far but do disconnect from carb before lubing the cable or you risk lube in your carb. Good luck!:cry:
  • Satch0922
Posted January 08, 2005 - 02:07 PM
Check your Pm's
  • Satch0922
Posted January 08, 2005 - 02:23 PM
if you get a Dr D hot start (btw....you will love it), make sure you lube the cable really good BEFORE you install it. Then the "plunger" that goes into the carb, put a very thin coat of lithum grease on it. And lastly, use clear ATV silicone sealant and seal around the outside of the cable where it goes into the plunger. This will keep water out of the plunger/carb area. Some users of the DR D unit have had the plunger seize in the carb due to water and rust. As long as you seal the outside of the cable as stated above and use a thin film of lithium lube on the plunger you will be ok. I usually take the plunger out and lube it about twice a year.
If you have any questions let me know.
Posted January 08, 2005 - 02:30 PM
We always had the problem Satch talks about with our 250F until we started adding a simple step to our wash routine. After we wash the bike, we run the engine just long enough to get it off the choke, then hold the rpm up a bit with the hot start lever held in for about 15-30 seconds. This clears the water from the airways around the valve, and as long as we do that, it never sticks. :cry:
  • Matt96xr6
Posted January 08, 2005 - 05:16 PM
LIke mentioned, be sure there is grease on that hot start plunger or they will stick. They are sticky from the factory on the 3rd gen+ FCR carbs. I have seen about 80% of the hotstarts stick out of the crate.
One word of caution on the DRD unit, since it is side loading the carb fitting, do not tighten the hotstart into the carb beyond about 5 in-lb. I did it more on mine and cracked the carb housing which caused the side to chip out. Some epoxy and it holds, but nothing like factory. The vertical units are much better on the 03+ carbs.
  • Hot  50 replies
  • Hot  113 replies
  • Hot  30 replies
