what chain do you run?
58 replies to this topic
  • inte
Posted January 07, 2005 - 08:16 AM
I just picked up my '02 YZ426 & everything on it is original stock. Hasn't seen much use, so it's all in good condition - but the chain sure seemed flimsy & showed some wear despite the sprockets looking good. A bunch of you mentioned that the stock chain is "tin-foil" in another thread I posted.
So now the question becomes - what chain should I run? I'm doing mostly desert/trail riding.
  • terrymc
Posted January 07, 2005 - 08:26 AM
I am using a Regina O-ring chain right now and it is wearing well. I'll be putting a new Moose O-ring chain on for an upcoming trip to Baja.
IIRC it's 520 and about 112 ~ 114 links (I just buy the 120 links and cut down)
  • yz400fl1
Posted January 07, 2005 - 09:20 AM
I had a Rental non-oring chain and it lasted for years. The only reason I changed it the other day was because I had to change the sprokets. Now I have a Regina Z-ring chain.
  • Jetsprint2
Posted January 07, 2005 - 11:24 AM
520 120 link D.I.D. ERT Gold chain. :cry:
  • crayztwentyseven
Posted January 07, 2005 - 12:19 PM
EK 520MRD chain. It has holes in all of the sideplates, :cry: it is much lighter than most other chains, been running it on ironman sprockets for 6 months and NO Visible wear! :cry: :cry: And I ride twice every week.
  • CRFThumper
Posted January 07, 2005 - 01:34 PM
D.i.d. Erv2
Posted January 07, 2005 - 02:39 PM
Regina's premium Gold O-ring chain. The most unstretchable, indestructible chain I've ever seen, including the DID X-ring. :cry: :cry:
  • BigDesto
Posted January 07, 2005 - 02:56 PM
DID 520 MX Strongest non-o-ring they make! :cry:
  • Satch0922
Posted January 07, 2005 - 06:52 PM
I ran the Regina gold O-ring on my 426 and did not have to adjust the chain from June-December!! And I rode it almost every weekend !
:cry:
  • JT_Thumpster
Posted January 07, 2005 - 09:43 PM
D.i.d. Erv2
wear index is very high and it has like an 8400 lb tensile strength, this will be my next chain.
  • DigilubeJay
Posted January 08, 2005 - 02:37 AM
Tensile strength, as well as wear index, is a marketing ploy.
Granted, if the tensile strength is rated high then the chain will be made of quality metal. However, the wear index of a chain is completely dependant on the care you give your chain and sprockets. (keep in mind that a 500cc 2-stroke can create about 1800-2000 lbs of pull on a good day...why do you need 10,000lbs of tensile strength?)
If you tend to neglect proper chain and sprocket maintenance, then you should choose a chain that allows you to ride for a good while without doing much of anything..ie a ring chain.
But, if you perform proper adjustments, cleaning, and lubrication you can enjoy even higher wear life from a standard chain than you can get out of a top-shelf ring chain.
Once a ring chain has consumed the factory placed lubricant, it is on a downhill slide that you can do nothing about, save for watch it grow and deform your sprocket teeth.
But with a standard chain that is taken good care of, you can see it's life go past that of a top quality ring chain. Due mainly to the fact that you can continue to provide it with fresh lubrication.
I currently use an EK 520 MRDG on my 444F. It has been a very good chain that is built with close tolerences. On sloppy/muddy rides, I mount up an RK XSO ring chain.
  • sirthumpalot
Posted January 08, 2005 - 02:44 AM
If money is no object and you want the maximum wear life, then the DID ERV2 is THE way to go! You''ll need a rivet tool to install it. The DID VM x-ring is also a great chain.
  • Satch0922
Posted January 08, 2005 - 07:12 AM
I disagree. Not from a theory perspective but real world experience. I have never had a regular chain last and resist stretching like the Regina O-Ring I had on my 426. I have used DID, RK, Renthal, Regina and this is the best chain by far. I currently have an RK GB520MXZ3 on my 05 YZ250 however it only has one ride on it.
  • JRAMBO
Posted January 08, 2005 - 07:33 AM
DID ert gold chain
  • crayztwentyseven
Posted January 08, 2005 - 11:22 AM
I agree completely with Digilude, I just keep my chain clean and lubed and I have only adjusted it twice in 6 months. And I ride a lot. My dad on the other hand does not ride much, and the other day we noticed that one of the o-rings was gone on his o-ring chain. Now it will wear that link much faster than the others. and eventually toast the sprocket. I also use the ek mrd chain:thumbsup:
  • Satch0922
Posted January 08, 2005 - 12:17 PM
torn or missing orings are typically from improper cleaning and maintenance.
Posted January 08, 2005 - 02:36 PM
:cry::thumbsup: I have never had ANY chain last and resist stretching like the Regina O-Ring!
BTW, the top of the line Renthal Gold R1 IS a Regina Gold. It just costs $15-$20 more with the Renthal brand on it.
  • ncmountainman
Posted January 08, 2005 - 03:27 PM
anyone have any experience with the CZ o-ring chain available from W.E.R. ?? $79 made in czekoslovakia?
Posted January 08, 2005 - 04:32 PM
No, but if the quality is anything like that of the motorcycles that company once built, it should be almost indestructible.
  • ncmountainman
Posted January 08, 2005 - 05:26 PM
i'm gonna give it a try,will let everyone know how it works. you can't beat that old world quality!:cry:
  • 10 replies
  • Hot  38 replies
  • 5 replies
  • Hot  28 replies
  • Hot  30 replies
