Rim Lock?
12 replies to this topic
  • NewBee
Posted January 07, 2005 - 07:18 AM
Can someone tell me and possibly show me what a rim lock is?
:cry: :cry:
  • ZEKEDAWG
Posted January 07, 2005 - 07:42 AM
http://www.cyclegear....cfm?L1=2&L2=64
Go down a couple items and you will see a taco shell looking device, that is it. I take it you have never changed your own tires?
  • Indy_WR450
Posted January 07, 2005 - 07:43 AM
http://www.rockymoun...OT_RIM_LOCK.JPG
  • NewBee
Posted January 07, 2005 - 08:12 AM
To be honest I have yet to replace a tire on my bike so I am more or less trying to learn before I have to.
:cry:
  • NewBee
Posted January 07, 2005 - 08:13 AM
What is the purpose of the rim lock?
:cry:
  • skeener2
Posted January 07, 2005 - 09:23 AM
It keeps the dirt tire from spinning on the rim. That would seriously rip your inner tube apart...and the whole not moving forward might be an issue.
Street bikes will spin out on pavement. But dirt tires with knobs...can actually grip and spin on the rim. This prevents it from happening.
  • Jackazz
Posted January 07, 2005 - 09:24 AM
It keeps the bead of the tire pinched against the the rim, so the tire does not rotate (from low PSI or high HP/Torque) & tear off valve stems.
  • Indy_WR450
Keeps the tire from spinning on the rim and tearing up the inner tube at the valve stem. :cry:
  • rockieman
Posted January 07, 2005 - 10:20 AM
And if you got a WR your rear tire will have two of them.
Makes it a MAJOR PITA to replace the rear tire.
  • Sylvain
Posted January 07, 2005 - 01:19 PM
All the answers are right, plus for the enduro/trail riders : It gives you the opportunity to ride back on flat tires. Very slowly, with tires that have protective sidewall for the rims. They exceed the width of the rim a little so it prevents contact with the ground, sometime.
It's better to have a spare tube. :cry:
  • timvv51
Posted January 07, 2005 - 01:50 PM
I removed one of the rimlocks on my WR and no problems. XR 650 only comes with one rimlock and it is the torque monster so I figured the WR could get by with only one.
  • Victor Champion
Posted January 07, 2005 - 01:55 PM
Same here.
Been running only one rim lock on my WR and no problems at all. :cry:
It's a major pain to change tires with these things. :cry:
  • new2blu
Posted January 07, 2005 - 07:29 PM
Or to install ultra heavy duty tube to prevent flats----I haven't had on yet! knock on wood!
