Xr650L Valve adjusting, torque wrench?
3 replies to this topic
  • bluerock5
Posted January 05, 2005 - 08:40 PM
After I adjust the valves, should I use a torque wrench to tighten the valve adjuster nut :cry: ? Thanks
  • michaeln
Posted January 06, 2005 - 04:58 AM
I don't, I just snug them up good with a 12mm combination wrench. Never had one come loose in over 34K miles.
  • dmrogers
Posted January 06, 2005 - 10:28 AM
Same here, I tighten them up while holding a good grip on the adjuster screw. We have four bikes and adjust them all this way. I am afraid that if I would try to torq them down it might affect the clearance adjustment.
:cry:
  • michaeln
Posted January 07, 2005 - 01:56 AM
:cry:
Good point. I have never been able to hold the adjustment with a screwdriver and have it be the same after tightening the nut, so what I do is set them a little loose, then tighten the nut while trying to hold it with the screwdriver. I then measure the clearance again, and it usually will have tightened up. It's a trial and error process, and if you do it a lot you finally get to where you can set them right in one or two tries.
Blindly torquing the nuts after setting the clearances would undoubtedly change the adjustment.
Honda XR650L 2017
  • 0 reviews
  • 22 replies
  • 2 replies
  • Hot  35 replies
  • 0 replies
