grease points on front and rear brakes
3 replies to this topic
  • lewichris
Posted July 30, 2001 - 05:12 AM
if you grease these where does the grease go. The bearings or the brakes or neather?
  • MN_Kevin
Posted July 30, 2001 - 05:54 AM
Dude, Keep the grease off the brakes, or you just won't stop!! :)
'99 WZ/YR (you choose!) with ALL YZ mods, de-octopused, DSP Doug Henry airbox w/ velocity stack, FMF PowerBomb header, Stroker SX-1 silencer, SS front brake line, OEM YZ tank, IMS YZ seat.
  • YamaCazi
Posted July 30, 2001 - 06:07 AM
What Lube points would those be ? Tell me you didn't put grease in the Hydraulic Bleed Valve's. :)
Bonzai.... :D
  • Scott_F
Posted July 30, 2001 - 06:30 AM
Pull the caliper off the carrier, and grease the two "float" pins and the holes they go in. Some people might grease the pad pins, but I don't recommend this.
