Valve Adjustment
3 replies to this topic
  • Jethrro
Posted January 02, 2005 - 09:01 PM
I have been wondering what kind of feeler guage set you use to check the valve clearances. The tollerance range is so tight and odd ball I'm afraid that a standard Inch or Metric is too wide inbetween to really get a accurate measurement without chasing it from one end to the other.
  • mjslim
Posted January 02, 2005 - 09:54 PM
I used standard inch feeler gauges with .001" difference between the sizes and they worked just fine. The intakes should be .004"-.006" and the exhausts .008"-.010". Don't worry about the 4 decimal place accuracy shown in the manual, its just a conversion from metric values. The most crucial thing I found was developing the proper "feel" with the feeler gauges. There is a subtle difference between the feel of a gauge that fits snugly in the clearance and one that is just a little too thick. If you push too hard with a gauge that is too thick, you can actually get the gauge to slide in the gap and fool yourself (you can actually force the valve open with the gauge!). To develop the "feel", start with a gauge that you know is too thin (e.g. .006 for exhaust) and step up one size at a time until you feel the gauge start to "pinch". It's a little awkward at first because you have to radically bow the feeler gauge to get it in there, but if you pay attention and repeat it a few times, you'll get it.
Good Luck!
  • simon@vic
Posted January 03, 2005 - 10:24 AM
I The most crucial thing I found was developing the proper "feel" with the feeler gages.
what he said. best way i can explain the "feel" is a very light vibration. VERY LIGHT.
bent narrow gages are a must for working on all yami 5 valve bikes. you can get them from yamaha or from k&l tools. good luck.
  • Jethrro
Posted January 03, 2005 - 05:00 PM
Thanks for the info will give it a try. Jethrro
