Idle Speed
3 replies to this topic
  • Rocky
Posted July 28, 2001 - 05:26 AM
I checked the previous posts but did not find anything specific to my question.
With the air box lid and the exhaust insert removed {everything else is stock} the bike idles and runs perfect.
With the stock exhaust insert or aftermarket Vortip installed ------ bike idles rough and there is a momentary hesitation (nano second) off the idle. It runs perfect other wise.
Before I start tearing into the jetting, is there a quick and simple adjustment for this problem.
  • Jason_Williams
Posted July 30, 2001 - 09:48 PM
Can you say (fuel screw)?? The exhaust plugs are making it run rich. start by turning down your fuel screw 1/4 turn at a time. That would be turning it in. or clockwise. is the bobble only off the bottom?
  • Rocky
Posted July 30, 2001 - 10:06 AM
Yes it burbles only at idle and up to 1/8 of open throttle. It carburets perfect everywhere else. It sounds like the typical fuel screw/pilot jet.
Thanks
  • Jason_Williams
Posted July 30, 2001 - 11:32 AM
Rocky, It shoudn't take much of an ajustment. When I run with my Vortip in I have to lean out the fuel screw or I get studder right off the bottom. good luck!
