red hot pipe
30 replies to this topic
  • motodawg
Posted February 18, 2005 - 10:04 PM
#21
The thinner, lighter stainless setup from DRD will cherry all the way back to the frame bolt when pulling off a night moto. People point at it and warn me that it's red! "Hey! Is that 'sposed to git that hot?" :)
  • NewhouseEnt
Posted February 19, 2005 - 09:51 AM
#22
My head pipe did that really bad. I found out I had an exhaust leak where the header slips onto the pipe. Check out for any pin holes or leaks with your hand while it's running. Mine stopped getting red after I fixed it.
  • yz450fensenada
Posted February 20, 2005 - 01:49 AM
#23
hahah yeah glowing pipe is cool !!
i enjoy watching my xr riding friends say wow !!! and also see them light up a marlboro on the head pipe hehhe :)
  • jdyz426f
Posted February 23, 2005 - 10:16 PM
#24
Agree ^^^^
Hey man try starting your bike at Night in the dark, now thats a red hot pipe ! :) :)
  • brock1732
Posted February 24, 2005 - 03:35 PM
#25
if my 99yz400 pops on decel, what should i do with the jets to correct that. I'm at sea level by the way
  • adrian
Posted February 24, 2005 - 05:10 PM
#26
I think we all should wrap our header pipe with some of that header exhausht wrap thats made for hot rods and such. I think it would help the motor run a bit cooler. What do you guys think? And a heat sheid to stop cooking the coolant in that radiator, I think would help also.
I run header wrap on my bike,no more burn the leg and the bike seems to run a little better..
http://www.thumperta...tachmentid=2684
  • YZ250F_Rider
Posted February 24, 2005 - 05:13 PM
#27
Header wrap is the only way to go. Just dont shred it with the power washer. :)
  • fatnugget
Posted February 25, 2005 - 02:03 PM
#28
Hey Brock, try adjusting the air mixture screw on the bottom of the carb, it sounds like you are a bit too lean. If I am thinking right, turn it in for richer out for leaner. I use to mess with mine all of the time until I bought the JD Jetting kit now it just seems to run right all of the time so I don't need to futz around with the air screw much at all anymore. BTW the stock setting is about 1/2 turns out from fully closed.
  • Geib2269
Posted February 25, 2005 - 08:48 PM
#29
this is brock1732 on my friends name. About the yz400....
i thought it was out for richer and in for leaner? I'm thinking about probably about 1/2 turns richer. Also, I have another problem, this probably has to do with fuel mixture also. When I rev it and let go of the gas, the idle stays high for a few seconds and then falls back down to normal idle. One more, I've been trying to adjust my idle but it seems like the idle screw is stuck and won't move clockwise or counter?
  • 02YZ426
Posted February 25, 2005 - 09:43 PM
#30
I have an 02yz426 and my header has always glowed red at idle. This has never bothered me before, untill I made the bike road legal. Now that its on the road, the pipe will glow right around the bend on the pipe while idling at the red lights. I never used to let the bike idle this long in the dirt or at the track. Do you guys think it will hurt the engine to idle more than a few minutes? Any suggestion on a new header that is thicker and is more resistant to the heat? (maybe to help prevent radiator boilover?) .........thanks!
  • sanpedro426
Posted February 25, 2005 - 10:49 PM
#31
Leave it alone, the thicker pipe is going to HOLD more heat because it is more material= more stored heat. Yamaha does know a thing or two SO STAY AWAY FROM the thicker stuff. And im not so sure that wraping the pipe IS a good idea either, JMO :) :)
  • Hot  38 replies
  • Hot  30 replies
  • Hot  28 replies
  • On January 15, 2017
  • Hot  36 replies
