clutch grabs as i pull off!
10 replies to this topic
  • nickjonesracing
Posted 02 January 2005 - 07:03 AM
I also have a small problem when i pull off the clutch grabs, can i adjust to fix this problem anywer?
  • John407
Posted 02 January 2005 - 10:58 AM
I'm not sure what you are asking. Are you asking if there is a way to get more free play at the lever? or is it that the clutch is not smooth when you engage it?
  • nickjonesracing
Posted 02 January 2005 - 11:43 AM
Wot is happening is as i release the lever slowly the clutch has an on / off action and grips to quickly!
  • John407
Posted 02 January 2005 - 12:11 PM
Sounds like my yz450, it shudders or grabs like that also. I didn't know that KXFs had the same trouble. Is the oil fresh? Does the clutch slip once you let go of the lever, maybe the friction plates are worn. In the yz I think the problem is not enough oil holes in the basket, my KXF has not had this trouble.
  • DDNMC78X
Posted 02 January 2005 - 01:28 PM
Try a different brand of oil.
  • nickjonesracing
Posted 02 January 2005 - 02:13 PM
Funny you mention the oil as i only just changed it today with semi syn fresh stuff ... i will drop oil and change bact to differant type.
  • DL126
Posted 03 January 2005 - 05:24 AM
Sounds like it's time for a new clutch basket.
What you describe is common when the "ears" of the basket get notched out.
Replace it with a Hinson & you'll get twice the life out of it next time.
  • Geib2269
Posted 09 January 2005 - 06:48 PM
i have a problem like that with my RMZ-250 it seems like the clutch is always grabing. When i pull it all the way in it is still hard to push and i feel a little pull. What should i do?
  • 4strokesrule
Posted 09 January 2005 - 08:08 PM
Shift to neutral to push it. Parasitic drag from rotating the geartrain.
  • binder929rr
Posted 22 January 2005 - 08:32 PM
ya, i have that bad, i hate paracites :cool:
  • nickjonesracing
Posted 23 January 2005 - 05:05 AM
after stripping down the clutch basket and hiub wer well grooved so ordered new 1's and hope this will solve problem!!!
