TT Decomp plug leaking....
6 replies to this topic
  • Chipstien
Posted January 01, 2005 - 10:00 PM
My trick little plug is leaking. Has infact since I installed it. Is this common or did I mess it up. Install seems pretty straight forward....... :cry:
  • yz426onNOS
Posted January 01, 2005 - 10:06 PM
Real men use decompression levers!
All in all, is there a seal that you may have forgot to put on or did you ocer tighten the bolt? Maybe you forgot the copper washer on the bolt.
  • yzfmxer
Posted January 02, 2005 - 12:38 AM
You probaly need a new rubber seal that the decomp plug kinda pops into.
I know the 02's had the seal because it had the decompresor shaft to seal, but im not certain if the 03,04,05's have it because of not haveing a manual decop. :cry:
  • yzfmxer
Posted January 02, 2005 - 12:40 AM
Whoops I didnt see that, until after I posted!
Ohh well
  • Satch0922
Posted January 02, 2005 - 04:53 AM
Is it leaking from the seal or the bolt? Mine leaked from the bolt because the stock bolt is a tad too long for the TT plug. I shortened the bolt a hair and that allowed it to tighten down flush with the head.
  • Chipstien
Posted January 02, 2005 - 08:52 AM
Right now it is impossible to tell whether it is leaking from the plug or the bolt since there is oil everywhere. I will clean it thoroughly tomorrow and then see if I can't get it to leak.
  • Vibeguy
Posted January 02, 2005 - 10:00 PM
Chipstein,
PM me with your mailing address and I'll send you a new lip seal. The plugs are unconditionally garenteed for life. This is only the second plug leak out of 1300+ plugs sold. The other was from a lip seal damaged during installation.
When you receive the new seal seat it on the plug then install both the plug and seal at the same time.
Fritz (Vibeguy)
  • On January 15, 2017
  • Hot  113 replies
  • Hot  36 replies
