A couple of questions
13 replies to this topic
  • simpledog
Posted January 01, 2005 - 01:45 PM
On a lark, I bought a YZF 426. This muther is a beast to start. What's the trick? Do I pull the red know out a bit? I know about the compression release, etc.
Also, where is the oil drain plug, under the bottom guard?
Lastly, it leaks a little water from a little hole, obviously a factory hole on the bottom of the engine, is this normal?
  • 250Thumpher
Posted January 01, 2005 - 02:55 PM
Well the red knob is a hot start lever. That lever is so when your bike is hot or flooded, you pull that lever out and it sends a lean mixture. The black knob next to it is the choke knob. Use this when the bike is cold.
There are two oil drain plugs (not sure about the 426 but possible the same) Tehre is one on the bottom of the oil tank, which is on the frame. The engine drain bolt is right under the shifter lever, a little to the left of it. Both of these bolts are 12mm socket heads.
-Phill
  • ncmountainman
Posted January 01, 2005 - 03:48 PM
the water from the hole means your waterpump shaft is leaking where the seal rides. common problem,and you should replace the shaft and seal asap. and the 450 cams with auto decomp would eliminate the starting dance you have to do with the 426 :cry:
  • OscarTHEGrouch
Posted January 01, 2005 - 03:53 PM
kick the bike over slowly until you come up to tdc and then give it a good hard kick and it should start right up ! :cry:
  • vetplus40
Posted January 01, 2005 - 06:26 PM
Bring the bike up on the compression stroke. You will feel the kickstarter get hard to move. If the bike has a manual compression release, pull in the lever and push the kickstarter down just a bit. Allow the kickstarter to recoil and kick the bike over just like any other bike. If the bike has not been started in a while, you may need a throttle blip to get some fuel into it.
  • yz426onNOS
Posted January 01, 2005 - 07:27 PM
Just replace the water pump seal. That red knob is the hot start. You use that instead of the choke when it is hard to start after a stall or fall while it is hot. The oild drain plug is under the glide plate. The best starting proceder for when it is cold:
-Kick the bike over 20 times while holding the decompression lever.
-pull choke
-give two blips on the throttle
-release decompression lever, kick the kick start till it stops (TDC)
-pull decompression lever and kick it 1 inch
-let go of the decompression lever and bring the kick strat back to the top
-kick it as hard as you can
If it wont start do this over and over again:
-kick the kick start till it stops (TDC)
If it is hot and you stall or fall do this if you think it is not flooded:
If it is flooded do this:
-pull hot start
If it wont start after 10 tries something is wrong. Like, fouled plug, idle is off, jetting is bad, out of gas.
When jetted properly it should start first or second kick every time. This is the best procedure!
  • yz426onNOS
Posted January 01, 2005 - 07:28 PM
Why in the hell do you need to replace the impeller shaft?
  • DPW
Posted January 01, 2005 - 09:28 PM
Try this, http://www.yamaha-mo..._stroke_fr.html
  • Satch0922
Posted January 02, 2005 - 04:49 AM
Try this
http://cgi.ebay.com/...923676&tc=photo
:cry: :cry: :cry: :cry:
  • DPW
Posted January 02, 2005 - 06:41 AM
Try this
Yeah that will help too... :cry:
  • Chris_from_Oz
Posted January 02, 2005 - 07:25 AM
I think he is referring to the fact that the water pump seal can sometimes wear a groove in the impeller shaft (the seal is fairly stiff, particularly in colder areas, until the bike reaches full operating temperature), and replacing ONLY the seal in cases like that, you'll still have a leak. From what i've read on TT, a few guys here have replaced multiple seals and shafts.....
  • ncmountainman
Posted January 02, 2005 - 07:38 AM
yes,the shaft is not that expensive and unless there is no groove worn in it (i'll bet there is)you should replace it while your in there! thats why in the hell :cry: and i can't believe more of you 426 owners aren't using the auto decomp cams. i have removed my starter and solely depend on the kicker,the thing rolls over like an xr200!!! :cry:
  • Satch0922
Posted January 02, 2005 - 07:48 AM
yet we still see the occasional "how can I put electric start on my YZ450" posts!! LOL :cry: :cry: :cry:
  • ncmountainman
Posted January 02, 2005 - 07:56 AM
that starter set up is crap!! its not worth the extra 13.5 lbs it adds to the bike. even with it on i was finding myself using the kicker half the time anyway. with the rekluse set up i don't ever stall anymore(even in a wreck) if yamaha had any brains they would make the starter a dealer option on both bikes(yz/wr) that way they would please everyone! :cry:
  • 0 replies
  • Hot  36 replies
  • Hot  28 replies
  • Hot  38 replies
