Carburetor rebuild
3 replies to this topic
  • johnsonm.a
Posted January 01, 2005 - 12:13 AM
I am thinking about rebuilding my Carburetor. I am having problems starting and I bought the bike used. Since its an older bike
99 YZ400 I figured I would go ahead and rebuild the carb to make sure I know whats been done to it.
Anyone know how much a a carb rebuild kit is and the best place to get one is?
Any tips or tricks when rebuilding the carb.?
Mike
'99 YZ400
  • gonzo
Posted January 01, 2005 - 12:57 AM
Is it cold outside where you are? You could try a 42 pilot and checking the valves. Also you dont really have to "rebuild" the carb. Just take it off and clean the jets out but I doubt that's what's causing your bike not to start.
  • condog_aus
Posted January 01, 2005 - 02:14 AM
You sure she aint ready for a top end. Usually starting probs indicate a need for the top end rebuild.
  • sirthumpalot
Posted January 01, 2005 - 06:00 AM
Mike
'99 YZ400
Check the valve clearances, especially if the starting problem is progressively getting worse.
As for the carb; if you remove the float bowl and shoot carb cleaner and compressed air through every hole, then the same through the two air holes in the front (air box side) of the carb, then through the fuel screw opening then that should do it. I believe on the older bikes the accelerator pump rod was not covered, so you may want to clean out the accelerator pump while you have it apart. DO NOT remove the plate that is held on by the funny headed screws.
  • On January 15, 2017
  • 10 replies
  • Hot  28 replies
  • Hot  38 replies
