Whenever I started my bike up today to go riding, a HUGE amount of oil started dripping out of one of the overflow tubes. It would not stop coming out. I would rev the bike and it would kind of stop but drip and as soon as i stopped revving it would just pour out like crazy. Any ideas of what could have happened? We sat there for awhile to make sure it wasn't just too much oil, but it just kept pouring out. I have an 04 RMZ250.
Oil Leak
Started by brock1732, Dec 31 2004 03:22 PM
6 replies to this topic
Posted 31 December 2004 - 03:22 PM
Posted 31 December 2004 - 03:38 PM
If it were me, I would start at ground zero. Drain all the oil out, and replace with a measured amount of fresh oil. Then start it and see if the problem still exists.
Merlinn
Merlinn
Posted 31 December 2004 - 06:36 PM
ok i will try that do you have any suggestions if that doesnt work??
So i can try it if ity doesnt work.
Posted 31 December 2004 - 11:46 PM
If you think about it there are a few reasons for the oil leak from the overflow hose. If the oil is not over filled it has to be gettig pushed out the over flow under presure. The first two reasons could be a blocked oil passage or more likely a broken ring allowing some of the combustion presure to pass into the crankcase. I sure hope you over filled it.
Merlinn
Merlinn
Posted 01 January 2005 - 04:04 PM
Did you remove both drain plugs when you drained the oil the last time? A friend didn't and putting in the amount of oil called for seriously overfilled the case. Funny thing is it doesn't look like you get that much out the small plug. Maybe if it isn't removed it traps some that normally drains out thru the bigger plug. Just a thought.
