Good Pro Tapers for tall rider?
18 replies to this topic
  • HeadTrauma
Posted December 30, 2004 - 10:55 PM
This seems to be a perpetual problem of mine; I always have straight arms and a bent back/knees because I'm so tall( 6'4" to be exact). On my '92 CR250 it was really a nuisance and while my current 600 isnt as bad, I think I could use a taller bar. I would like to stay with Pro Tapers, but will consider others. Does anyone in my height range(or knowledge of it) have a suggestion or recommendation?
  • rokklym
Posted December 31, 2004 - 07:52 AM
Tag makes the T2 kit which comes with oversized bars, the mounts and a bar pad for $129.99. They are available in the CR double Hi bend which is 8/10" taller that the CR Hi's, plus the mounts add 3/4" of rise to the bars too. So thats a pretty good height increase for not alot of $$
  • don87xr600
Take a look at the Maguras as they are generally taller. I've tried the CR high, the YZ high in the protapers, and have a set of Magura MX2 on the way. I'm 6'4" also.
  • mjlang
Posted December 31, 2004 - 09:26 AM
You can go with CR High bars with a GPR Type II damper (under bar design) and this will lift your bars significantly.
If you look in the catalogs, the bars measurements are shown in sweep back from center and rise above center. Compare the different manufactures until you find the one you want. Tag Metals makes a bar and I don't remember the bend, that by the sweep and rise numbers was the highest/straighest bar I could find.
  • SMOKE
Posted December 31, 2004 - 03:12 PM
that is what i have on my 650r and love it i am 6'5" and it is still kind of short but a hell of alot better. plus the stabilizer has saved my ass a couple of times well worth the 500 bucks imho
mike
  • jws
Posted December 31, 2004 - 07:21 PM
mike
i am 6' 4" and i have this set up also
pic 1
pic 2
or - you can go with the thumper racing bar risers and the renthal jimmy buttons
pic 3
pic 4
jeff :cry:
  • HeadTrauma
Posted December 31, 2004 - 10:07 PM
Thanks eveyone. I wish I knew what ProTapers I have because those bar risers look like the hot ticket for me. Granted I dont spend alot of time on my feet, I'd like it to be comfortable when I do.
  • don87xr600
Posted January 01, 2005 - 12:33 AM
the model name of your protapers is under the right grip.
  • rokklym
Posted January 01, 2005 - 09:28 AM
Those Thumper racing risers look nice. Do you have a link to them or a part #.
I looked on their website but didn't see anything.
  • jws
Posted January 01, 2005 - 11:06 AM
i picked them up from www.bajadesigns.com :cry:
jeff :cry:
  • XR4DEZ
Posted January 01, 2005 - 03:25 PM
The tallest Tapers are KX high.
  • 1biglung
Posted January 01, 2005 - 03:40 PM
I went with the Tusk 7/8" to 1 1/8" adapters and Longhorn CR Hi bend bars. It is much better. Here are some before and after pics.
Before 1
Before 2
After 1
After 2
Now I am waiting for the big bar adapters for the Bark Busters.
Hope it helps
  • don87xr600
Posted January 01, 2005 - 06:08 PM
the pastrana freestyles are a half inch taller than the KX high bend
  • HeadTrauma
Posted January 01, 2005 - 07:17 PM
Well, I'm not going to waste a $10 set of grips just find out what bend I have.
Before 1
Before 2
After 1
After 2
Hope it helps
Those pictures help. My Tapers look similar in bend/height to your "before" bars.
I looked at my triple clamp and bar mounts and didnt realize that it woud be so easy to make new riser bottom halves. I work in a machine shop, so it wouldnt be hard.
  • don87xr600
Posted January 01, 2005 - 08:28 PM
can you make 2 sets :cry:
  • 1biglung
Posted January 01, 2005 - 08:33 PM
I can take closer pics if you want and take some measurements.
I thought about the same thing but for $35.00 for the adapters and $39.00 for the bars I chose the easy route. :cry:
  • HeadTrauma
Posted January 02, 2005 - 01:09 AM
Thats the other thing; most of the time it costs less for me to buy what I want than it does to build it. An example is when I built a pile of small increment jets for my carb before I knew my jetting problem was largely a bad coil connection. :cry: On the other hand, Kehin jets arent the most accurately made things in the world. Mine get incrementally larger by .0005", while Kehins can vary .001" between two of the same sized jets. It only cost me about $10 to make each jet and would cost $5 to buy them.
The only exception is if something doesnt exist. Thanks for the measurement offer, but I have the parts I would duplicate on my bike and its always easier having one to look at/compare to in my hand.
  • Outrider
Posted January 02, 2005 - 06:44 PM
Nice baja kit, I just installed mine and I have the exact same mirror too. :cry:
  • 1biglung
Posted January 02, 2005 - 07:07 PM
Thanks,
Not a Baja kit it's a CR250/500 rear fender, BD tail light and WB flushmount turn signals.
Fender was a pain but looks good and slims the 650L's a$$
Fell Off Trailer by usafxr
  • Hot  43 replies
Washington
  • Hot  32 replies
  • Hot  186 replies
  • Hot  35 replies
  • 9 replies
