Check valve clearance or not?
4 replies to this topic
  • redmanrandyed
Posted December 29, 2004 - 07:37 AM
I have a 2000 XR650R and have not checked the valve clearances yet. The question I have is do I need to check and adjust the valves if the bike is running great? Are there any signs of valves needing adjusting? When should one check and adjust the valves?
Thanks in advance,
Redmanrandyed
  • Old_Man_Time
Posted December 29, 2004 - 08:29 AM
Thanks in advance,
Redmanrandyed
Odds are if it starts easy, idles nice and has great power through out the range it's ok. If you are comfortable doing valves that have a auto-decomp, check them for peace of mind.
:cry:
  • Mokuleia
Posted December 29, 2004 - 10:51 AM
How does the auto decomp effect valve adjustment? As long as you end up at TDC on the "T", and there is play in the rocker arms, should one be all set for adjustment?
Hoping I didn't miss something....
  • JackAttack
Posted December 29, 2004 - 11:33 AM
:cry:
My bike was starting great and running great. I decided to check the valves anyway since I had the tank off. The intake valves were tight. It had much more snap after that, and I did not even notice the bike was running a little flat before. :cry:
:cry:
  • Old_Man_Time
Posted December 29, 2004 - 11:57 AM
You will know that the auto-decomp kicked in if when you start it there is a very loud tapping. If you allow the motor to kick back even a little when your turning it over to find TDC the auto-decomp will set. If you had play in every valve before you loosened and adjusted them, your fine. :cry:
  • 4 replies
  • 3 replies
Honda XR650L 2016
  • 0 reviews
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
