2000 YZ426F Problem -- Please Help
7 replies to this topic
  • jumpinjerryk426f
Posted December 28, 2004 - 06:30 PM
The problem started as the throttle is snapped the engine coughs then powers up. When the throttle is rolled on it the power is all there!! :cry: Just when you need a quick snap it dies b4 accelerating. Does it at half throttle also. :lol:
I cleaned the carb. Twice, air filter is clean, tried to adj. the air screw and put in a new plug. I even changed the accelerator pump. No change in problem. :D
The new accelerator pump parts listing did not specify difference in the 4 different ones available, so the parts guy said order the first p/n, it should be the original one anyway. :cry: The new one came in with the number 3.7 on it. The one I took out of my bike is a 4.3. The throttle response was better but still has the snap cough. :D The parts guy wouldn't refund me the part for exchange for the 4.3. :cry:
Tonight when I started it, it was hard to start. It took about 3 kicks for it to fire off then die. Did it about 7 times. :D I got it to stay running by giving it some gas. It sounded like crap then. :cry: It ran, popped and backfired repeating in that order as long as I kept some gas to it. The eng. RPM was erratic but would not idle. :lol:
What's wrong?? :cry:
  • WR426madness
Posted December 28, 2004 - 06:38 PM
On my 02 426 I cliped the A/P spring off at the bend on the cam side and rebent it this made the pump spring a little stonger. Then you will need to do the BK mod so you can adjust the duration of your A/P. do this and I promise you won't be sorry. Also you may need to bump up your pilot jet one size. If you need more info PM me.
  • ThumpDave
Posted December 28, 2004 - 06:39 PM
sounds like its running lean - had the temp changed quite a bit
you might try to adjust your needle in the carb down (I believe) a notch and then get you an adjustable air screw like a (ZipTy)
  • Matt96xr6
Posted December 28, 2004 - 09:25 PM
Do a search for the BK mod and get a Zipty fuel screw (or other brand extended unit).
The jetting is way off on the 2000 model. On mine, I did the BK mod and JD jetting kit. Then adjusted the fuel screw and there was no bog.
  • jumpinjerryk426f
Posted January 01, 2005 - 02:48 PM
I went to the track the day after my post and the popping and backfireing quit. :cry: The temp. was up about 25 deg. It ran real good except for the snap bog. :cry: I had plenty of power. Enough to have no problem landing the 100 ft. tabletop. :cry: I had to deal with the snap bog when taking 90 deg turns trying to snap out of them. :cry:
  • John_Lorenz
Posted January 01, 2005 - 04:29 PM
The Bog is a known issue in the 2000 two things you can do
1: get the 2001 Needle, this will clean up the mid snap
2: the GB mod is a must on the 2000 follow this Link GBMod
  • SSpeeDEMONSS
Posted January 02, 2005 - 07:42 PM
the 2001 needle is the same clip wise it? it's just different in shape(correct wording?)?
  • John_Lorenz
Posted January 03, 2005 - 07:59 AM
Mmm K :cry:
  • Hot  47 replies
  • Hot  113 replies
  • 10 replies
  • Hot  38 replies
