Keep losing plug on crankcase cover
7 replies to this topic
  • nevadajay1
Posted December 28, 2004 - 08:46 AM
Just ordered my second replacement plug for the crankcase cover (smaller of the two). Appearently it is backing out as I ride, and then I look down to discover an open hole with oil seeping out and dirt getting in! Anyone else having this problem?
  • Jackazz
Posted December 28, 2004 - 08:48 AM
Two words:
Safety Wire
  • wildo
Posted December 28, 2004 - 08:49 AM
I never heard of it make sure the theads are in good condition and try using lock tite.
  • nevadajay1
Posted December 28, 2004 - 08:50 AM
Once installed, the plug is flush with the case. I can't visualize how to drill it out for safety wire. Sugestions?
  • Jackazz
Posted December 28, 2004 - 10:42 AM
Try drilling it at an angle, from about 2mm away from the slot in the middle & angle the bit so it comes out at the deepest part of the slot. & remember whatever you wire it to should be secure & in such a location as to apply tension in the tightening direction. Maybe add a bead of silicone all the way around the plug after you install & wire it for added protection?
  • Indy_WR450
Posted December 28, 2004 - 10:45 AM
You most likely have a bad plastic plug again. Order another replacement. I have not heard of this issue on any of the WR's or YZ's . I doubt the threads are not machined correctly in the case. Plastic plug is most likely bad on your replacement plug as well. :cry:
  • Jackazz
Posted December 28, 2004 - 12:22 PM
nevadajay1, this is a total shot in the dark, but if you've lost several of your timing plugs, I wonder if you should look for a couple of symptoms...
1. Overtightened plug - The plug is plastic, & if overtightened could crack the threaded portion (which you might not see) & make it much more suceptable to falling out.
2. This one is the big stretch... Blocked/kinked crankcase breather hose - Too much pressure in crank case will follow the path of least resistance to get out. I would think that it would simply blow the breather hose off of the top of the valve cover rather than poping your timing plug, but I guess you never know. :cry:
Maybe it's even some combination of all of the above. :cry:
Good luck :cry:
  • purluvwr450
Posted December 28, 2004 - 04:17 PM
I had the same problem with mine so I just put a small peice of duct tape over it and it has stopped all the problems, doesn't look really good but it does the job.
