Leaking Oil - Where it came from I have no idea
11 replies to this topic
  • tomrayner
Posted December 27, 2004 - 04:11 PM
Hi All - I'm hoping someone might be able to give me some insight - I'm not much of a mechanic. I am trying to figure out where I am / was leaking oil out on my last run. I'm riding a 2004 YZF450. About mid-way through our run last weekend I noticed oil running down the inside of my frame underneath the radiator - it was also falling onto my pipe (the smell and light smoke as it burned caused me to discover it). The leak did not seem to be significant - wherever it was coming from - we had to run 20 miles back to the truck before we could leave - I checked the oil level at several stops and did not have a noticeable drop. The bike made it back fine - I ran it pretty hard (just wanted to get back) and did not have any noticeable drop in power. Myself and the guys I was riding with were a little perplexed - we could not locate where the oil came from. I took it back to town and used a pressure washer to clean the frame section where the oil was located to see if I could find a crack in the frame, then started the bike and let it run for some time. I could not find any cracks and no additional oil showed up. I don't want to destry the bike - if there is a problem, I'd like to figure out what it is and fix it before my next ride.
Had anyone else ever had this problem? Are there any techies out there who can think of a good reason why I'd have oil down the frame on the bike?
Posted December 27, 2004 - 04:32 PM
Look for a hole about a half inch in diameter in the front of the head, about 10 o'clock from the header. That's the bore where the decompression lever used to go. The chintzy little plug they used to cork it up blows out without warning.
If it's gone, welcome to the club.
Order one of these: http://shop.thumpert...egory_s/342.htm
to solve the problem.
Slam an OEM plug back in the hole while you wait if you have to go riding. Check your breather hose to make sure it isn't pinched, too. :cry:
  • nzz900
Posted December 27, 2004 - 04:34 PM
check out whether you lost your decompression-plug which is just a rubber plug where the decompression cable used to be hooked up to before they went to automatic. you will find it on the right hand side, in front at the cylinder head. best to just feel around with your finger. happens. I always carry a spare, I think they only cost a few bucks...
  • tomrayner
Posted December 27, 2004 - 04:49 PM
Thanks Guys!!! Will check it when I get home from work tonight!! Thanks for the quick reply - I appreciate it!
  • tomrayner
Posted December 27, 2004 - 09:44 PM
You guys nailed it!!! :cry:
Thats what makes these forums so great - I really appreciate the feedback and help.
Another quick question and I will leave you alone......did I do any damage running without the plug? Do I need to take any precautions - or do I just buy a new plug and install it, problem solved?
Thanks again for your time!
Posted December 28, 2004 - 09:50 AM
Usually, nothing bad happens as long as A) you didn't run out of oil; or :cry: no significant amount of dirt got in through the missing plug. You can pop the cam cover off to check for dirt intrusion if you're worried, but you can get a pretty good idea by looking up the open bore with a mirror, too. Do an oil and filter change anyway, and remember to check for a pinched breather hose. The plug can just fall out, but blocked breathers are the cause about 10-20% of the time.
Do plan to do something about the plug. Replacing it with the stocker and calling it done won't work in the long term. Get the TT plug, use a steel cup plug, make a retainer for it, wire it in, something. Otherwise,...
As far as nailing it, this was a softball. Besides, when the bike only has 4-5 real problems, it makes it simple to diagnose. :cry:
  • Wayne_Thompson
Posted December 28, 2004 - 10:03 AM
Thanks guys for the info!! I know you just saved me from coming and asking the question when mine blows out
  • HS624KS
Posted December 28, 2004 - 07:55 PM
If you go with the TT plug like I did (or some variant) don't be a dumb@ss like me and overtighten the little bolt that is used to hold the plug/decomp lever in place. There's not much for thread on it.
Can you say Heli-Coil? I'm now a trained installer after this brain-fart. :cry:
Love the 450 by the way.................. :cry:
  • Wayne_Thompson
Posted December 28, 2004 - 10:40 PM
That is the biggest problem I have. Wanting to overtighten! :cry:
Posted December 29, 2004 - 10:12 AM
One way you can screw this up is not to have the plug in far enough (or too far) so that the groove in the plug's shaft doesn't line up with the hole for the retainer bolt. If this happens the bolt could run up against the plug before a reasonable amount of thread was engaged. Use a punch as a guide tool to line the groove up with the hole if you aren't sure that it is.
  • YZ250F_Rider
Posted December 29, 2004 - 10:48 AM
you spell it torque wrench.
  • skthom2320
Posted December 29, 2004 - 10:54 AM
Torque wrench doesn't help if the plug is not lined up.
  • Hot  30 replies
  • Hot  36 replies
  • Hot  38 replies
  • 5 replies
