YZ426 rear susp linkage, how many seals?
5 replies to this topic
  • Guest_BrandonV_*
Posted December 27, 2004 - 12:34 PM
I ordered the Pivotworks linkage bearing kit and it came with 8 seals, I only count 6 when the linkage came off and on the Yamaha blow-up diagram.
Am I missing something here?
Thanks.
  • Matt96xr6
Posted December 27, 2004 - 05:04 PM
There is 8 of them. Be sure to get the connecting rod ( the U shaped part that connects under the rear motor mount to the frame.
You can see the parts fische here:
http://parts.yamaha-motor.com/
Look under "rear arm"
  • Guest_BrandonV_*
Posted December 27, 2004 - 05:20 PM
Even that only shows 6. Four #24's and two #36's, not including the swingarm pivot area.
I wonder if they included 2 extra for the inner swingarm pivot point but since I also bought the swingarm bearing kit (which included those) I dont need it. Anyone else bought this kit and knows?
  • Guest_BrandonV_*
Posted December 27, 2004 - 05:24 PM
Be sure to get the connecting rod ( the U shaped part that connects under the rear motor mount to the frame. http://parts.yamaha-motor.com/
Is the U-shaped piece you're referring to #19 on the diagram?
  • Matt96xr6
Posted December 27, 2004 - 09:29 PM
no. In the 2002 model, #31
So you have 4 in the Linkage relay arm, 2 in the connecting rod and they may include 2 for the lower shock bearing seals depending on the year the kit is designed for.
  • Guest_BrandonV_*
Posted December 28, 2004 - 07:44 AM
Ohhhhh....... I guess I should've mentioned that I have a 2000. I checked the 02' diagram and it looks the same, it must be for the lower shock bearing seals as you stated.
Thanks.
  • Hot  36 replies
  • Hot  30 replies
  • Hot  113 replies
  • 0 replies
