XR650L ; How do you adjust the valves....?
2 replies to this topic
  • bluerock5
Posted December 23, 2004 - 01:54 PM
Is it hard to adjust the valves and how do you do it and what tools do you need? Thanks
  • mountainrider
Posted December 23, 2004 - 05:05 PM
Remove the fuel tank.I f you do not know how to remove the tank,do not try to adjust the valves. :cry: Remove the inspection plugs on the valve cover.Remove the plugs on the left side engine cover.Rotate engine counterclock wise until the T lines up with the notch.If you go a little past the T do not turn it back.Go all the way around and try again.Adjust valves to 004 intake and 005 exhaust.A socket set,wrenches and a screwdriver. :cry:
  • Haymaker
Posted December 23, 2004 - 05:21 PM
You'll have to find the gap for the "L", but here's the basic procedure. http://www.xr650r.us/tech/ . Last link down.
E
