How long is the YZ throttle stop?
2 replies to this topic
  • Flip01
Posted December 22, 2004 - 01:34 PM
Just pulled the carb out to install the ZipTy fuel screw and check for the throttle stop mod. Looks like the dealer did install the YZ stop but I just wanted to make sure. The throttle stop screw measures 23.15mm. This sound right?
  • Jackazz
Posted December 22, 2004 - 01:41 PM
That depends on what you measured... the bolt "shank", or the whole bolt (head & all). The YZ one is 11mm shorter than the WR one. If I recall correctly, my WR's stock bolt "shank" was ~28mm long (not including the head), so ~17mm after cutting it down.
If you measured the length of the whole bolt, I'd say that your measurement sounds about right.
  • Flip01
Posted December 22, 2004 - 01:49 PM
DOH! Sorry, yeah the measurement I gave was for the whole screw all together.
