My ORV sticker won't stick!?!
12 replies to this topic
  • Johnny34
Posted December 19, 2004 - 11:04 PM
I tried to put the new ORV sticker on my WR high on the fork tube and it won't stick! Either the dealer put so much greasey polish on it that it wont adhere, or the fine grooves that run around the tube are preventing good contact. So where the hell should I mount this thing? The law says it has to be visible while riding and preferably on the fork tube. :cry:
Johnny
  • MadDawg
Posted December 19, 2004 - 11:10 PM
You should clean the area that you want to place the sticker on with alcohol. The fork is typically greased up to slide it through the triple trees when assembled to prevent damage to the finish on the fork. :cry:
  • WR450F_RDR
Posted December 20, 2004 - 07:26 AM
I had a similiar problem, I ended up putting it up higher on the forks near the headlight. Clean the area real good with rubbing alcohol.
  • holeshot
Posted December 20, 2004 - 11:51 AM
I just use clear packing tape. I cover the sticker with plastic wrap first so that the tape won't stick to the sticker (in case I want to remove it and tape it back on again). The plastic wrap isn't really necessary, though.
I don't remove the "peel off" thing on the back of the sticker.
  • Gadsen
Posted December 20, 2004 - 02:30 PM
Clean it well with brake cleaner. Not carb cleaner, though, it will work, brake cleaner drys up real fast and leaves no residue behind. In fact, spray it on a rag and wipe the area clean. This works prefectly for installing graphics too! :cry:
  • Rich_in_Orlando
Posted December 20, 2004 - 05:16 PM
Go to your local Home Depot and get a fluorescent light bulb protector tube. They are made of thin clear plastic. Cut a piece of the tube long enough to fit where you want it to fit on your fork tube, then make a slit all the way down it lengthwise. Now you cans slip it over your fork and stick the sticker to that. It will stay with no problems and you can remove it when you need to like when you take the forks off to service them. Been doing this for years.
  • Beef
Posted December 20, 2004 - 06:53 PM
I don't know where you live, but it may be too cold for the glue. Wipe the fork with alkohol, then try using a hair dryer to heat the fork up till it's nice and warm (like 80' F or so) put the sticker on, then blow it some more, while rubbing any air bubbles out of it. It'll stick. Just don't get it TOO hot.
  • Johnny34
Posted December 20, 2004 - 09:29 PM
:cry: That is a freakin' great idea. I would have never thought of that.
Beef: It is a little cold here and I think the greasey polish plus the cold is what's doing it. I've got some isopropyl alchohol wipes that should clean her off real good.
Johnny
  • Beef
Posted December 21, 2004 - 04:33 PM
Hey Johnny, I just noticed you are from Oregon. What part? I am from the Portland area, but have done some riding near Bend, as well as the dunes. I would imagine the eastern part of the state would be a lot like it is here in Boise.
  • barefootbob
Posted December 21, 2004 - 04:41 PM
I had the same problem clean the area upper fork the hairdryer was the trick I used.stisks good with heat
  • Johnny34
Posted December 21, 2004 - 07:53 PM
I'm from Kalifornia originally and been in Portland since 2000. Two guys I work with have been begging me to finally get a dirtbike and ride with them. I can't wait to break in my WR and hit the trails with them. I think we're gonna start with Browns Camp in Tillamook and go nuts. I can't wait!
Riding in the forrest will be a big change from the high desert near Victorville, CA. I just need to take it easy at first.
Johnny
P.S. sorry for hi-jacking the thread :cry: wait a minute, this was my thread!!! Nevermind.
  • Beef
Posted December 21, 2004 - 08:14 PM
Browns Camp rocks. That's where I learned to ride! There are MANY trails, with difficulty from beginner to XXX. Just keep in mind that most are single lane trails with blind corners, and there are idiots that fly through there with no regard to other riders. As long as you are fully aware of your surroundings, you'll have a great time though.
I can't wait 'till next summer, so I can visit family and go for a ride at Browns Camp...I'll prolly save half the day for Sand Lake too, which is just about a half hour further west.
  • simica
Posted December 21, 2004 - 09:58 PM
The idea of using packaging tape to cover the sticker or mounting the sticker on any other surface and then attaching it to the fork tube for future quick removal is not a good idea in California. I am a volunteer at Hungry Valley SVRA and the rangers get very suspicious of these mounting methods and will detain you until they run the registration on your bike and then probably issue a citation for improper mounting.
