yz450f crank question
5 replies to this topic
  • rbm33
Posted December 19, 2004 - 04:50 PM
does anyone have a picture of the timing chain gear on the end of a 450 crank??
im doing a rebuild and it looks like the gear is worn, kinda looks like an old sprocket and there isnt alot of material on the peak of the gears. i just broke a valve and bent 3 other valves and im not sure if it jumped time because of the gear or if i just broke a valve and damaged the others.
any help would be appreciated.
  • jimmyg
Posted December 19, 2004 - 05:00 PM
i just replaced mine when i took it apart the teeth were severely worn the timing chain in these things chew them up i wish they would put a replaceable gear on these things it would be a lot easier & cheaper to fix that way.
  • rbm33
Posted December 19, 2004 - 07:59 PM
did you replace the entire crank or just the half with the gear on it?
  • jimmyg
Posted December 20, 2004 - 05:43 PM
i replaced the whole thing although you could get away with half im not sure if it would cause a balance problem or not never tried it.
  • rbm33
Posted December 22, 2004 - 06:39 PM
a few pics
Posted Image Posted Image
  • jimmyg
Posted December 23, 2004 - 06:01 PM
:cry: :cry: :cry:
  • On January 15, 2017
  • Hot  30 replies
  • 10 replies
  • Hot  47 replies
