stiff suspension
6 replies to this topic
  • TIM696
Posted December 17, 2004 - 06:07 PM
I have an 03 yz450f with stock suspension and weigh about 175 pounds and always feels stiff even after lowering the fork oil a little bit. Trying to soften it up a little bit without paying for after market suspension any helpful advice.
  • yz400fl1
Posted December 17, 2004 - 07:01 PM
Man, that is a light 450, 175lbs!! J/K :cry:
My 400 was pretty stiff and I didn't want to spend a grip of money to get the suspension done so the dealer said to drain the stock oil and get thiner stuff, lighter weight oil. Worked for me :cry:.
  • Davidyz450
Posted December 17, 2004 - 08:42 PM
Did you set your sag or mess with the compression adjustments at all? I have an '03 and it seems a little soft to me.
  • TIM696
Posted December 17, 2004 - 08:43 PM
sorry bike doesn't weigh 175 I weigh 175. what kind of oil did you use and how many cc's from the top?
  • TIM696
Posted December 17, 2004 - 08:45 PM
yes I set my sag at 100mm but still seems stiff in the front
  • sirthumpalot
Posted December 18, 2004 - 05:29 AM
Don't be afraid to play with the clickers, they will make a huge difference. Start with the stock settings and venture from there.
  • 426mankiller
Posted December 18, 2004 - 12:22 PM
Go to this website for info on setting up your suspension:
http://motoman393.th...suspension.html
even if you soften it up (ie take out compression front & rear), the YZ is a race bike that is internally valved for landing on long jumps so if it is still too stiff for what you are doing with it you may need a revalve.
  • 5 replies
  • Hot  36 replies
  • 0 replies
  • 10 replies
  • Hot  50 replies
