05 -wr450 Baffle help
1 reply to this topic
  • pudadin
Posted December 17, 2004 - 09:57 AM
Has anyone removed the baffles on the 05 wr450....if so is it worth the hassle?
  • mark2025
Posted December 17, 2004 - 10:51 AM
It is not much of a hassle. 5 min job at best.
Just remove the allen screws from the pipe and pull off the cover (the two rivets DO NOT need to be removed). Then remove the 4 screws that hold the baffle in. Replace cover and you are done.
This will at least double the size of the pipe opening and only increase the noise a slight about...still very "quiet" compared to aftermarket pipes.
