Can you replace the squirt nozzle
5 replies to this topic
  • motocrosschump
Posted December 16, 2004 - 08:28 AM
My brothers bike AP spray is more of a light mist than a stream. I have used compressed air, carb cleaner and its not any better. Can I replace the the nozzle itself?
Posted December 16, 2004 - 08:39 AM
No, it is pressed into the carb throat.
Bonzai :cry:
  • Pothole
Posted December 16, 2004 - 09:36 AM
I had the same problem. Did you take the slide out of the carb and put a rubber tipped air nozzle directly on the AP jet? That's what worked for me.
  • adrian
Posted December 16, 2004 - 11:26 AM
Try using some oxy/cetaline welding tip cleaners, you can buy them at any welding shop and they go very small in sizes, might be just enough to clean out the spray tip
  • yzwiley
Posted December 16, 2004 - 12:33 PM
The problem could be a bad pump diaphram. And if you do get a new diaphram be aware that you can purchase leaner and richer diaphrams for the accelerator pump.
  • motocrosschump
Posted December 16, 2004 - 02:13 PM
already replace the diaphram. I will try the cleaner.
  • Hot  36 replies
  • 9 replies
  • 0 replies
  • Hot  33 replies
