Shorten wheelbase
5 replies to this topic
  • dunecj2a
Posted December 13, 2004 - 09:18 PM
:cry: I wanted to shorten the wheelbase on my 450 by running a 15 tooth front sprocket and a 52 rear. :D Does anyone know if there are any pros or cons to this set up. :lol: I figured with this set up it would be like having a 14/48 1/2 tooth gearing. :cry: My track has a lot of tight turns with big doubles and tables right out of them. I really like the stock gearing but feel that I could use a little more bottom to clear the stuff :cry: Any advice :cry: THANX!!!!! :cry:
  • Fastest1
Posted December 13, 2004 - 10:54 PM
What does that have to do with shortening your wheelbase? :cry:
  • big t
Posted December 13, 2004 - 11:15 PM
Just drop 1 tooth on the front sprocket. Running a 15/52 you would probably end up increasing the length of the chain which could end up increasing the wheelbase. Also dropping 1 tooth on the front will be cheaper. Did you move the forks up some in the triple clamps? That should help your handling.
  • sirthumpalot
Posted December 14, 2004 - 03:34 AM
If you want to shorten the wheelbase, take a link out of the chain (measure first to make sure it's still long enough!!!). That will slide the rear wheel up a tad.
Then if tight turning is your goal, raise the forks up in the triple clamps.
  • YAMAKAZE
Posted December 14, 2004 - 05:14 AM
Thats the Ticket..... Especially raising the forks...That will dramatically shorten your turning radius.
Bonzai :cry:
  • Satch0922
Posted December 14, 2004 - 09:32 AM
raise the forks 4-8mm...works wonders
