Well it finally happened!!!
30 replies to this topic
  • Steviejay01
Posted December 13, 2004 - 05:19 AM
Chain wore though the rubber guide and damaged my fecking swingarm (not to bad mind).......ordered a new guide, 2x new sprockets, a 14 front and a 42 rear, + a heavy duty O-Ring chain, gonna try that mod with the silicone under the guide, heard you can also use like a bike innertube??, just fold it up and clip it under the guide, nip it down at the screw points??????
Is the idea to raise the guide a little in the middle to stop the chain slapping about so much??
just wanna clear it up, should have it tomorrow morning.
Also why do supermoto chains slap about so much?
Never seen a bike chain move about as much as this one does!!??
  • Indy_WR450
Posted December 13, 2004 - 05:28 PM
There have been many posts on this over the years. Get a heavy TM designs slider and put a half inch of High temp silicone gasket under it. Let it dry overnight and bolt on the slider with a long bolt right thru to the other side of the swingarm slider mount. Solves the swing arm chain slap wear issue. :cry:
  • Steviejay01
Posted January 06, 2005 - 07:12 AM
And what everyone was banging on about doing....
The chain seems to stop slapping about as much now on the top, much more smooth, but I'm just a little worried that maybe there is more preassure on the guide than before, could this cause it to wear faster??
I did notice when I sit on the bike the chain gets tight (of course) and LIFTS up off the guide a bit, does this look right then??
  • Jackazz
Posted January 06, 2005 - 07:34 AM
I've never heard of anyone spacing the mount up with washers before... I think you're just supposed to mount it down like normal... :cry: Someone will be along to awnser, I'm sure. BTW, from what I've heard, most guys who run SM setups on Yam's "eat" chain sliders, due to the smaller CS sprocket & higher speeds.
  • dangermouse007
Posted January 06, 2005 - 08:26 AM
You boys had any problem with the Chain rubbing the Sub Frame ??? Steve where did you order your chain slider from.....Fell the Need for a spare...
  • simon@vic
Posted January 06, 2005 - 09:44 AM
most guys who run SM setups on Yam's "eat" chain sliders, due to the smaller CS sprocket.
don't you mean smaller RR sprocket :cry:
  • Steviejay01
Posted January 06, 2005 - 09:45 AM
Cant remember now bruv but if you go here and contact (John)
http://www.macmoto.com
He can order you one.
I'm not gonna let anyone else touch my bike now this chaps been working on it.
Really nice guy, can get you ALL your bits and bobs, fits and supplys wheels/tyres and just about every other bit you will need.
Wondering if Jackazz might be right, mebby I should remove the washers, just thought if I keep it all in line it will line up better, when I sit on the bike the chain comes no where near the new bolt and washers due to the swingarm moving up and lifting the chain.
  • Jackazz
Posted January 06, 2005 - 09:51 AM
Well, actually, from what I've heard, guys tend to run smaller sprockets front & rear, so I'm sure that doesn't help the slider much.
EDIT: I stand... er sit... actually, corrected. It appears that the biggest difference is reduction in size of the rear sprocket Most guys probably stick with the stock size front. Good catch S@V :cry:
  • Guy
Posted January 06, 2005 - 12:41 PM
ahh.....most people I know, go up to a 15 for the front and run 42 or there abouts for the rear...
leaving the stock 14 on and then runing a 39 or similar runs the chain way too close to the swing arm and round to tight a rdius for any decent chain life ! :cry:
  • Jackazz
Posted January 06, 2005 - 12:58 PM
Funners, is that you? :cry:
What you doin' on this here 'merkin forum? :cry: You might quickly become the unofficial WR forum supermoto "expert". Seems to be alot of people popping up here lately doing SM conversions. I've been posting links to VD for your countrymen for awhile now, but dunno if any of them have tried the place out.
  • WR_Dave
Posted January 06, 2005 - 01:27 PM
You need to get those spacers the H#ll out of there. The stock washers are usually too loose and can be tightened down by putting a socket over them and tapping them down. My .02---WR Dave.
  • Steviejay01
Posted January 06, 2005 - 01:30 PM
So just remove the washers and we are good to go then yea??
Funners thread jacking my thread eh!!
You wait till I see you on VD you .....you......thread jacking Wh0re.... :cry:
  • Guy
Posted January 06, 2005 - 02:08 PM
:cry: AHhhh Jackazz.........check my join date ! :cry:
  • Guy
Posted January 06, 2005 - 02:10 PM
Moi ???? Threadjacking ???? :cry:
Shurely not ! :cry:
  • Jackazz
Posted January 06, 2005 - 02:47 PM
Yeah, I noticed it after making the post... of course. :cry:
You still sporting your "Captain Morgan Parrot Bay factory leathers? :cry:
So if I understand correctly, you rid yerself of that italian 2 wheeled disaster & rejoined the ranks of the blue army?
(this is a propper threadjack, BTW... :cry: )
  • Guy
Posted January 06, 2005 - 03:18 PM
:cry: ROFL...well I still have my colourful leathers...YES ! :lol:
and err.....Italian ??? it was Swedish ! and it wasnt a disater...it was fun..but the chance for a WR rose and I took it ! :cry:
  • new2blu
Posted January 06, 2005 - 07:34 PM
Dangermouse,
Yes I have had some evidence of the chain rubbing the subframe. I need to engineer something to fix this.
  • new2blu
Posted January 06, 2005 - 08:05 PM
Dangermouse, see this link for chain to subframe contact.
http://www.thumperta...ad.php?t=212118
  • Brettv
Posted January 06, 2005 - 11:55 PM
G'day, i put a thick strip of insertion rubber on mine and some auto silicone,
by the way, i see you have a nice carbon fibre swingarm guard....whered ya get it?
thanks
  • dangermouse007
Posted January 07, 2005 - 02:25 AM
New2Blue... Thanks.... Chain is fitted ok, its a new Xring chain, so gonna add a lenght of cable ties for the moment, then think about a metal plate or something.....
