19" wheel on WR?
9 replies to this topic
  • r_dawg1021
Posted December 12, 2004 - 06:29 PM
I found a good deal on a complete wheel. The only problem is that it's off a YZ and it's a 19" wheel. Anybody see any issues with using this wheel as a spare for my paddle tire? I'd use the 18" stocker for dirt and the 19" for the sand. Thanks for any feedback :cry:
Also, he had the sprocket and disc on it as wheel. I don't think I'd have to change my components to allow a good fit with my calipers and what not would I? :cry:
  • RADRick
Posted December 12, 2004 - 06:53 PM
Shouldn't be a problem so long as you check the overall diameter when mounted. The 18" wheel gives the WR a taller sidewall, which is better for hard terrain and rock crawling. For sand, tall sidewalls isn't really necessary and most sand tires have a low profile so that the paddles will clear.
  • wr_power
Posted December 12, 2004 - 07:30 PM
if the wheel is off an 03 or 04 should be ok, don't know about pre 02.
  • OrionEngineer
Posted December 13, 2004 - 07:25 AM
I have a 19" YZ wheel on my '99 WR 400 for street use and it works great. No issues with the caliper or sprocket. Good luck.
  • r_dawg1021
Posted December 13, 2004 - 07:55 AM
Thanks for for the feedback guys. Looks like I might just buy this thing..better than spending $700 on a new one.
Posted December 13, 2004 - 10:05 AM
Try and use the same sized sproket on the new wheel as the old one so that you don't wind up having chain issues with one being larger or smaller that the other.
Just a thought...
Bonzai :cry:
  • jwriott
Posted December 13, 2004 - 11:16 AM
I had a 19" that I ran on my WR426 for the dirt and used the stock 18" for dual sport tires. It worked fine and I ran a Maxxis 120 on the 19" rim.
I also kept the sprockets the same size as Yamakaze suggested so changing them out was quick.
Posted December 14, 2004 - 09:48 AM
I'm using a 19" on my WR426.
  • Math
Posted December 14, 2004 - 10:12 AM
Same here.
18'' for dual sport and 19'' for dirt on my 426
I would have like to do the opposite because of the sidewall issue but the choice of dual sport tire is very limited in the 19'' size.
  • pattch
Posted December 14, 2004 - 11:52 AM
Great info. I have been looking for a spare for my 01' WR426 and all I can find are 19". Anyone need a 18" paddle tire. :cry:
